Hyperflashing with lasfits led lights after the Ford turn signal recall fix???
Alvin23
Alvin
Vacaville
2022 xlt hybrid
Purchased and installed the first lasfits led lights over a year ago to replace my turn signal bulbs. After the Ford turn signal recall update, my turn signal module detected an error resulting in hyperflash. I contacted lasfits to inquire if there is a possible solution unfortunately, nothing they could do with the current led lights. But they engineered an update to remove the hyperflash. They offerred me a generous discount to replace the led. Hyperflash is resolved and i am no longer annoyed by the clicking sound. Kudos to Lasfits team!
Ford Maverick Hyperflashing with lasfits led lights after the Ford turn signal recall fix??? IMG_2390
Ford Maverick Hyperflashing with lasfits led lights after the Ford turn signal recall fix??? IMG_2389
Chris_G
NOVA
C-6 Corvette
Hopefully you did better than 50% discount
unclerunkle
Aaron
Wisconsin
Grand Marquis
Had the recall done today and am experiencing the same issue :(
Reaching out to Lasfit...I don't think 50% off is all that generous. Should be a free replacement for the trouble.
Mavman321
Joe Schmo
I have posted the fix if you guys use Forscan
unclerunkle
Aaron
Wisconsin
Grand Marquis
Not so much a fix but a hack to disable rear tail light outage monitoring. Much prefer to leave the monitoring on with updated Lasfit builbs.
Mavreezy
Peter
Long Beach, CA
Mazda B3000 Dual Sport, Lincoln MKZ Hybrid
Are these for the rear or the front?
I started getting the hyper flashing only on the gauge cluster after the Ford recall was completed. The front and rear bulbs do not hyper flash.
I contacted Lasfit and they told me that they currently do not have a solution to address the hyper flash issue on the Lariat model. Fawwwwk....
NJBob
New Jersey
So the Lariats are different from other trims?
wjg
William
Mustang, Maverick
It's not Lasfit at fault, 50% seems real generous.
90south
Missouri
2022 Maverick Lariat AWD
Actually, I don’t see where OP said what % was offered.
wjg
William
Mustang, Maverick
Does it matter? Lasfit did not cause the problem, why are they offering any discount is my point. Be thankful they are.
Big C
Cecil
Palm beach florida
2023 Maverick XLT
Question did you only replace the two turn signal bulbs or all four of the rear tail light bulbs?
donaldtr54
Donald
Wheat Ridge, Colorado
Thank you, I’ll have to get ahold of them.
RoyalTeaDee
North Carolina, USA
Dodge Caliber R/T
Lasfit offered me 50% off as well to replace both sets of rear taillight bulbs.
Should hopefully have them early next week.
I personally don't fault them. They were made/designed for the vehicles as we bought them. They had no way of knowing there was an issue and that the update would cause this.
90south
Missouri
Doesn’t matter to me. I don’t have a dog in the fight. Seemed that a few comments were insinuating that 50% was enough. I was just pointing out that the OP never stated a % amount. Lasfit should do what they feel is best for their company.
