Turn signal recall with Lasfit Bulbs
Chris_G
NOVA
C-6 Corvette
I received this response:
Thanks for bringing this matter to our attention.
We found out that the issue is related to the Ford with a software update because of a bug that would not recognize if one of the two rear signal/brake lights was burnt out.
Our T-WT21W-R rear turn signal/brake/tail light bulbs can work correctly before the update, but won't function properly after the software update.
Could you please tell us the trim level of your Ford Maverick? So we will offer a solution.
Look forward to hearing from you, thanks.
Dmat
Baton Rouge
MAVERICK
From the email I received from Lasfit.
Hello,
Thank you for reaching out about the issue you have.
Yes, we also discovered that the issue is related to the Ford with a software update because of a bug that would not recognize if one of the two rear signal/brake lights was burnt out.
For this situation, our newly released T3 series could be a suitable solution.
Easily learn more in this link: https://www.lasfit.com/products/425...d-bulbs-t3-series?_pos=4&_sid=cf7682b4c&_ss=r
As this issue is related to the software update rather than the LED bulbs, we regret to inform you that we are unable to provide the new T3 series bulbs free of charge.
However, as a valued customer, we would like to offer a 50% discount to purchase 2 pairs of T3 series bulbs, could that be acceptable to you?
Kind regards,
Wency
Lasfit Customer Service
Chris_G
NOVA
C-6 Corvette
Hello,
Kind regards,
Wency
Better than nothing 😁
simon_eddy
Ron
Mount Joy, Pennsylvania
2023 Ford Maverick XLT.
Baily2000
Long Island
2022 Maverick Lariat HPR
Just picked up my 22 Mav Lariat from dealer. Had the turn signal recall completed. Like everyone else with the Lasfit bulbs I now have the dash hyper flash. Will contact Lasfit…
Rentman1225
Greg
Rockford, IL
Forde Maverick XLT LUX
Hello,
Kind regards,
Wency
I received a similar email but was offered a 30% discount. I replied that a 50% discount would be acceptable (seeing on this forum that others were offered 50%). They agreed to the 50%.
First Sergeant
Fruitland Idaho
They offered me the same deal. I'm ok with that, others are not. Lafit had no crystal ball that told them Ford was going to do an update and no one knew the bulbs would not work properly after that update. Anyway, It cost me $63 additional bucks and I got the T3 series bulbs. Installed a few days ago and work perfect..... Until Ford screws that one up! Still got the older stye LED's, wonder if they will work when/if Ford issues an update to the update? I seriously doubt they are concerned about us folks and our LED bulbs.
Chris_G
NOVA
C-6 Corvette
I'm out of my one year warranty period. Anything Lasfit will do for me is appreciated.
gp1200x
Paul
NY
Actually it really is a LASFIT issue and not a Ford issue. If they had their LEDS perfectly match the resistance and characteristics of the halogen bulbs that Ford was using then they would not have had this problem. That's what happens when these Chinese manufacturers reproduce parts that don't work properly due to poor initial design work and improper testing. If it was truly a Ford problem it would have shown up using the stock bulbs. Don't count on Ford to provide any fix since this was the fix to repair a defect whereas the software was not acknowledging the loss of a bulb due to resistance differences. LASFIT would be losing a lot of their already made profits if they gave out free replacements. Even at 50% off they are still making a handsome profit I bet. LED bulbs are still way overpriced.
Chris_G
NOVA
C-6 Corvette
Appears we have gone from 50% to 30%, no bueno!
Thank you for reaching out to us.
For this situation, our newly released T3 series 4257 bulb could be a suitable solution.
Please kindly note that this bulb can directly replace the WT21W bulb since they have the same socket.
However, as a valued customer, we would like to offer a 30% discount to purchase 2 pairs of T3 series bulbs, would that be acceptable to you?
Best regards,
Vichan
Baily2000
Long Island
Just received this reply from Lasfit:
Yes, we found out that the issue is related to the Ford with a software update because of a bug that would not recognize if one of the two rear signal/brake lights was burnt out.
Unfortunately, we don't have a solution specifically for a Ford Maverick Lariat.
But we would refund $50 for these T-WT21W-R bulbs, may we know if it is ok for you?
Question: is there a LED replacement out there that will work and fit on the Lariat? Either I stay with the Lasfit bulbs and the hyper flash, reinstall the original equipment bulbs, or another LED replacement from another company 🤔
Chris_G
NOVA
C-6 Corvette
You can always use a load resistor if all else fails. I must admit that I'm disappointed with Lasfit.
First Sergeant
Fruitland Idaho
Best regards,
Vichan
Bummer. This can sure be a hassle. I think if I had it to do over and knowing what I know now, I would not have had the turn signal update done by Ford. I simply do not need that safety factor. Been driving since 1967 and most of my vehicles until the last few years never had that feature. AND I NEVER DIED AND NO ONE RAN INTO ME AND DIED! I park in a garage and even on the new Mav, I check turn signal, brake and headlights and yes, the horn every time I pull out. I can see them on the walls, don't even have to get out of the truck. I just don't need about 90 percent of this type junk on cars today. Every little thing that may harm someone, even once is an automatic DANGER and the word SAFETY gets the "knee jerk reaction way too often. JMHO.
Baily2000
Long Island
Load resistor? Where would I get those and would I need (4) for the brake and turn signal rears?
Chris_G
NOVA
C-6 Corvette
