Lariat front turn signal LEDs with latest Ford update
gp1200x
Paul
NY
Anyone have recommendation for a good set of the 4257NA front amber turn signals for a Lariat. These are the non-swithback leds that only supply an amber turn signal. I want a fairly cheap but good pair brighter than stock that also do not cause hyperflashing with the new recent Ford update. I want something much cheaper than Lasfits.
Vickram
Dearborn Michigan
Blk 23 Mav Lariat , 09 Escape ,72 honda 350 cycle
LASFIT 3157 LED Bulb 3056 4156 3057 4057 4157 Turn Signal Light Amber Only CANBUS Ready Error Free Built-in Load Resistor Anti-Hyper Flash Automotive Blinker Max 2600lm, ONLY for Standard Socket(2pcs) $50.00 and sinfully bright . Mine can be seen 1/4 mile away .
Don't go cheap on quality , this should be a one time purchase, go for it .
  • Like
Reactions: Dad
Jetlat7878$
Woodstock GA
2024 Maverick Lariat Blackout
If anyone has a 2024 Maverick Lariat, the Lasfit T-3 series bulbs will not work, Lasfit now states that fact on their web site and in fact the bundle kit now omits the red T-3 bulbs for the Lariat. I tried those bulbs and they hyper flash.
The solution that works for me is to purchase from Headlight Revolution the following:
Tail/Brake/Signal
Four GTR.LED 285 Lighting Armor Series 4257 LED Bulb Red
Four Morimoto Resistors 40Watt 7.5ohm
Front Turn Signals
Two GTR. LED 284 Lighting Armor Series 4257 Amber
One (2 Pack) Ultra GTR Pro Resistors 6ohm
This option works with absolutely no problems with hyper flashing . Not difficult to install by any DIY type or have a shop install them for you.
Also Digital Dynamics has LEDs on their web site that are designed for the Lariat but I haven't tried them.
Jetlat7878$
Woodstock GA
Tail/Brake/Signal
Front Turn Signals
Jetlat7878$
Woodstock GA
Tail/Brake/Signal
Front Turn Signals
gp1200x
Paul
NY
Tail/Brake/Signal
Front Turn Signals
Still up about $60 just for the front and you have to hack the wiring all up. I don't mind wiring by adding a fuse tap and adding my own wires but I want to stay away from cutting up the factory wiring while under warranty. My stuff I can just unplug. I'll wait until someone makes an LED that actually works properly. There is no reason a company cannot make a reasonably priced led 4257 that has the same characteristics as a standard filament 4257.
dadd75
Upstate South Carolina
www.universityofheaven.com
2022 Maverick Hybrid Lariat, 2013 Buick Encore
I just had all the software updates finished today with my MY22 Lariat hybrid. I installed the Lasfit LED bulbs when my truck was new, and now, after the software updates, the blinkers hyperflash. Is there a solution to this? Thanks!
MM Mav
Amy
Great Lakes Region
Dad
Tail/Brake/Signal
Front Turn Signals
It was my understanding that the front turn lights were not the cause of the hyperflash but rather the rears. I have a 22 Lariat, with Lasfits for the front turns and T33 for the rear which I used to replace the older LasFits that caused the hyperflash after the recall. I'm not sure if the 24 Lariat has a different wiring system by which many members are saying the T-33 do not solve the problem.
Jetlat7878$
Woodstock GA
That appears to be true. However, I didn't want any more issues with canbus ready bulbs. So the solution is to use non canbus bulbs with resistors. Thant's what I did and everything is working properly. LEDs are very expensive isn't ive so trying various fixes can be costly. The installation of the resistors isn't difficult at all. I watched a guy on youtube install resistors on his Maverick so I did as he did and wham bam it works.
  • Like
Reactions: Dad
Dad
Totally get it. I put non canbus leds on my 2007 Ford E-450 and installed the resistors separately. A bit more of a trouble, but still easy. Hardest part was figuring out where to hide them.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
I just don't understand this at all- the OEM front turn signal bulbs are BRIGHT. I can see them reflect off signs or other objects in the daylight.
