Hybrids are really hard on engines - you tube video
Chops
Lobo
If I see some hybrid specific oil, I'll buy it if the price is equal to or less than the factory recommended oil . Otherwise, it'll stay on the shelf. 😅
I won’t argue about price shopping off the shelf motor oils as long as they meet Ford’s spec. Most millionaires would agree with that strategy.
I do pay a bit of a premium buying my full synthetic 5W-30 from my local Ford parts counter though. A few extra bucks - but I’m hoping they’ll greet me by name someday:)
My opinion: the benefit is probably theoretical just like the problem is theoretical since there's no present problem happening. The real benefit is to their profits. Again it's my opinion. And my opinion is probably worth as much as you paid for it😅
Hmmmm! How much per hybrid maverick did Ford pay you?😁
Darryl
Darryl
Tallahassee Florida
2025 Maverick XLT HYBRID
I wish they did 🤣. But the truth of the matter is that hybrids don't need different oil. Hybrid engines already last just as long as their non-hybrid counterparts. In the Maverick it may be even a bit longer. Although I am a Ford guy, I really do believe in the Maverick because as a tech, I see what breaks and doesn't break. For example, I would be very cautious about buying a 1.6 or early 1.5 4-cylinder EcoBoost. And I'd avoid the 1.0 liter 3cyl EcoBoost altogether unless the updated wet belt oil pump tensioner has been installed.
Escapologist
Niagara Region, ON
Would have to go way back maybe to 2.0 Duratec to find a Ford motor that worried me less than the 2.5... some of the current honda and toyota engines would worry me more.
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
Have You seen any issues with the 2.0 EB MPC engine in the 2025 Mavericks or the Escapes since they started using this engine in them in 2023 IIRC?Thanks
Darryl
Darryl
Tallahassee Florida
Although our shop is small, so we may not see everything that’s out there. But I can’t recal
Although our shop is small, and we may not see every issue like the larger shops, we do see enough to recognize significant issues. And to be honest, I cannot recall us replacing or doing major repairs on any 2023 and up 2.0 ecoboost. If it was a problem engine, we would have replaced or repaired a few by now given the number that come through our shop . Some of the previous generation 2.0 EcoBoost engines in the previous generation escape did have some head gasket issues. But the 1.5 EcoBoost was the worst. Incidentally, the 1.5 3 cylinder used as the base engine in the escape and bronco sport has largely been problems free as well
@Darryl
I. Would like to add a button, lever, or whatever to spray windshield WITHOUT WIPER. Idea being to soak and soften bug juice for awhile before wiping. I could save 2/3 of my wiper fluid but the main reason would be not refilling reservoir as often.
JBMAV24
Jeff
Shelburne Falls, MA
2024 Maverick XLT
Hard on engines???
My friend, whose 2008 Prius still has just about original everything (and loads of miles), apparently hasn't gotten that memo.
We had a 2002 Prius that we drove for 15 years and put nearly 300,000 miles on it. If I hadn't totaled it, it would likely still be going. I replaced the battery at 11 years, and put in a set of wheel bearings. Other than that just regular maintenance (hybrids can be tough on tires with the weight, but there are more choices in tires today). Prius hybrids are not hard on engines, more likely they hardly use the engine. Our other hybrid now (besides the Maverick) is a plug in Prius (2022).
cyberdog
Ray
2023 Maverick Lariat Hybrid
As long as the oil meets the Ford published WSS-M2C962-A1 spec, there shouldn't be any issues. That spec is for BOTH the Hybrid & EB engine family, and most oils on the market meet or exceed that spec. I reached out to Warren, who bottles quite a few oil brands, and they confirmed that Walmart's Supertech Full Synthetics ALL meet the Ford specification.
Escapologist
Niagara Region, ON
I ran supertech at 15,000 mile intervals on a 90s CVH, was inside it for HG at about 140,000, bores fine, could feel the hone on them still, 100,000 miles later, into it for a cooling failure.... bores seemed exactly the same as 100,000 previous, no scuffs on cam, no gunk, no sludge, clean as anything. So I'd use Supertech again in a heartbeat if I was buying my own oil.
Mavster Mechanic
Hybrid
@Darryl
So it's not just me.
100% agree the liquid is wiped off way too quickly. Usually before having much of a chance to do anything.
Nice if there was a manual override, like press and hold or something so you can get a quick wipe when need (say at highway speed) and a slow wipe or not at all while stopped.
If you tap the wiper lever down and release the wipers will wipe once! You can continue holding the lever down and it will slowly wipe until you release it.
Ya - but spray some fluid first and pause before it wipes if auto is the only mode given. Maybe that pause or lack is based on speed - never tested that.
Or old style - just the spray button on the end.
Really coat it if needed sitting at light.
I have not found how to spray without wipe on lariat hybrid. No spray button on end or anywhere. Pull lever away from dash just sprays and wipes. Maybe is I just barely pull lever part way it will spray and not wipe. I'll try that.
Phimosis
Larry
Santa Clarita, CA
My observation: most of the people who have the most complaints horror stories about the reliability of a Ford or Toyota hybrid are people who have never owned a Ford or Toyota hybrid. And most who have complaints about the reliability of a Ford hybrid versus a Toyota have only owned the Toyota hybrid and never owned the Ford hybrid. With the Ford Maverick hybrid the only consistent complaint isn't really about the hybrid system. It's just the battery drain that some experience
This is off-topic adjacent, but I’ve had a couple of coworkers complain about the perceived longevity of their hybrids (Honda CRV and Hyundai Elantra) because they were expecting an Otto-cycle-like experience, but what they got was the typical Atkinson cycle experience: poor low speed and poor high speed torque production and poor throttle response, which means that the engine needs to be programmed so that whenever it is working modestly, ie climbing hills, it is spinning between 4,000 and 5,500 rpm, to negate the inherent deficiencies of the Atkinson cycle engine.
And they were seriously concerned - without evidence - that this behavior was going to cause their new car to blow up, in short order.
