Hybrid 12-V battery settings and options - used or not?
If you have followed the battery issues for any time - you've seen reference to Forscan says the Hybrid is setup to use an AGM battery already, and charging scheme, with an 80% SOC setting also seeming to be meaningful.
Some that get new batteries (AGM or FLA) change that setting to 95%, with comment it works great.
Of course that just changed 2 variables - so which was the improvement - setting or new battery?
Several with scanning systems also report that despite that setting change, 80% seems to be the top level SOC seen.
Some of us see nothing better than 65%.
Some report new battery issues down the road.
The default charging scheme seems to be the same that many makes/models use with alternator controlled by PCM/ECM - high charge level during starting run time, backing off to lower charge level as time goes on - sooner as you get closer to 80% SOC (65% for Maverick). That will change if the system load is high to higher Voltage charge (not on Maverick as DCDC-Converter supplies 12V system separate from battery charging Amps).
So I'm hoping someone with computer Forscan can really look at that setting, and these other settings.
I've only got Forscan Lite on android, and when I show any of the PIDs that are specific to battery - while they have a setting to use, they don't display that any is used. I'm thinking the whole batch isn't used.
So I'm wondering if it's a batch of settings left over from the software in other models, or included for potential use and then didn't use it, or figures are set, but nothing seems to care about them?
Here's what the PID's display during running. I'll mention other hard set PIDS (like reference Torque value, or user setup for TCU comm) do display correctly with their setting, whether options are available in it or not.
This is not an issue of scrunched screen not showing the selected value - there is no value to show.
Here are the options available to display for those PIDs, if one was actually checked. The example check mark you can discern happens to be in the middle merely showing an option could be selected. Battery Capacity and CCA has no values in them, nor are any displayed.
This is where I'm curious if the computer Forscan merely shows AGM at top of list because alphabetical order, and it's not actually checked to be used. I've not used that program to change any settings, so I've got original data.
With as many reporting that their scan gauges never showed being at 80% either, I'm wondering if that's a setting actually used by the charging logic.
Especially when ones have changed it to 95% and fail to see a change to the max charging level.
I'm really wondering if the values used by the system are totally based on what's seen during the 8 hr relearn with doors locked, and either that is coming up with bad figures, or sensors are bad for really calculating Amp flow, and micro usage to determine SOC by the end of the 8 hrs.
Because these values do change regarding Battery Charge/Discharge, mine are at 6 now for top 2, still only 1 (Ah perhaps?) for Discharge during sleep mode. Which I've never gotten a warning about on Fordpass app.
Any takers on Forscan program, with pics of the options displayed for these PIDs regarding Battery?
Ohhh, tough time to start a new thread.
To some of those PID's and possible values - the other point is for a self-maintenance item - who is going to enter the data correctly for the system to use?
And how entered?
That's why I'm wondering if none of them are used.
Manual under Spec's for EB makes it sound like some are used, from this footnote (not used in hybrid section though):
1 Configure your vehicle’s battery management system to match the replacement battery. If using a battery not listed, it must match the specification as one of the listed batteries. Configure your vehicle’s battery management system to match the listed battery. Failure to use an appropriate configuration for your battery management system could result in shortened battery life, features not working correctly, or your vehicle not starting. Consult your local dealer or service provider for further details.
What's the failure rate for people resetting their OLM after an oil change, even with as easy as the truck makes it?
Never mind other makes/models that requires a little routine to accomplish - which may be findable on web search, but how many vehicles have you been passenger in where owner never did it?
Anyone with Forscan access back from vacation?
And currently unadjusted parameters to the above PID's?
ShadowBlack XL440
Robert
Northern Ohio
Mike, I am having the battery saving mode issue now and plan on a AGM replacement. I will check with my dealer first to see what their current process is, test and replace with flooded or AGM. Based on their reply, it will be on their dime or mine, one way or the other it will get an AGM upgrade. I have Forscan on a PC and if you can advise what you need to see from the stock MY24 settings I will do what I can to help.
I think I'm planning on getting my 1st warranty battery and selling it to offset getting an AGM.
That would be great. Just curious if there is a default setting on these already, or just a list of options available that matches my pictures above. Last 2 may have values in them, not sure how they get there. Little screen grab if 4 can be displayed at once might be interesting.
Under the Body Control Module BCM section.
The PIDs for (not sure how the Descriptions will display for you compared to my pics above).
BATT_DES
BATT_MAN
BATT_SIZE
BATT_TYPE
BATT_CAP
BATT_CCA
Thanks much.
ShadowBlack XL440
Robert
Northern Ohio
BATT_DES
BATT_MAN
BATT_SIZE
BATT_TYPE
BATT_CAP
BATT_CCA
Thanks much.
I will try that but don't recall seeing any display like this in Forscan. I do recall seeing battery type and charging levels. I just asked my dealer if they would upgrade my bad battery with an AGM and was told no, it would be the same flooded battery. Not sure why they think this would fix the problem.
Uncle Ed
Georgia
1968 Camaro, 2017 Toyota Highlander, 2024 Maverick hybrid
I will try that but don't recall seeing any display like this in Forscan. I do recall seeing battery type and charging levels. I just asked my dealer if they would upgrade my badd battery with an AGM and was told no, it would be the same flooded battery. Not sure why they think this would fix the problem.
I believe they are going to follow the manufacturer 's policy as the dealer will only be reimbursed by Ford by installing what Ford requires. I see an AGM battery in my future.
ShadowBlack XL440
Robert
Northern Ohio
BATT_DES
BATT_MAN
BATT_SIZE
BATT_TYPE
BATT_CAP
BATT_CCA
Thanks much.
Some screen shots from Forscan on my stock MY24 XL Hybrid
I will be installing one of these bluetooth monitors tonight to gather actual battery status and charging information.
billpitman
Pa
Mach-e
Hey Robert, I purchased & installed one of these 4 days ago! Looking at the history, do you see a very brief voltage dip every hour?! Since current draw is suppose to be like 1.5ma., can’t believe it would be from tha, right…… no real way to check…… Bill P
ShadowBlack XL440
Robert
Northern Ohio
See the attached screen shot of my battery status over the past 3 days. You can see during my 35-40 min. drive to work the battery is charged @ 15.4V to about 12.4V state then falls off to 12v or below. It just wont hold a charge while setting due to some reason. Not sure if it is a constant draw or just a bad battery. My AGM battery is due today, after an over night charge, I will install and reset the BMS per the owners manual instructions.
billpitman
Pa
Mach-e
Please look at a 1 day period, can you see a quick dip in voltage, about every hour?! Bill P
inline_five
2023 Hybrid XLT
Bill, Does this help?
Something is draining the battery down while it sits (at work?). From 8am to 4:30 pm. Is that normal on a vehicle? I'd imagine not.
The battery isn't the problem, the problem is the truck is doing whatever it does while it sits idle and voltage is dropping to low levels.
@HeyBales this is a good thread. I've ordered one of those bluetooth voltage monitors off AliExpress and plan to test what you've mentioned. I'll look at stock, then change one thing at a time to see if anything actually makes a difference.
ShadowBlack XL440
Robert
Northern Ohio
I suspect the battery is bad and will swap it out this weekend with the AGM. Then I should have some good information to compare.
UPDATE- Major delays caused by Fedex damaging the new AGM battery. Now to see how difficult it will be to get a replacement.
