12 V H4 AGM battery at Costco
Dluep1
Don
2023 maverick xlt
thanks
JT Maverick
New Jersey
Cancunbadlands
Cancun
Cancun
I have a '23 XLT Hybrid (35 months old, 22Kmiles). Never failed to start or gone to deep sleep, but it has been increasingly going to battery saver and cutting things like entry lights. Dealer says battery tests a little low, but not in warranty. Was in Costco recently and they had the Interstate H4 AGM battery for $137 + tax + $3 disposal fee + $15 core charge (36 mo prorated warranty, 480CCA, 52 Ahr, 75' reserve). To try to avoid problems over the winter, I bought it Monday and installed it Tuesday. Estimate it to take about 40', took me a little longer because I had a slip up. No need to remove housing, you need a long extension and a magnetic pickup. Remove the neg first then the hold down bolt & clamp, then slide the battery to get clearance to remove the Pos clamp. Remove battery and reinstall in reverse order. Then reset BMS.
How to reset BMS?
710-oil-614
Cal
2025 Hybrid AWD Lariat
Yeah, I see both the $189 and $94.92 versions when I search for
"EverStart Premium AGM Lead Acid Automotive Battery, Group H4"
This should work:
Free Shipping! EverStart Premium AGM Lead Acid Automotive Battery Group H4, 535 Cold Cranking Amps, 80 Minutes Reserve Capacity - Walmart.com
I see 2 primary differences - 535 cold cranking amps and 3 year replacement warranty ($95 version) vs 540 cold cranking amps and 4 year replacement warranty ($189 version).
Neither of those warrants double the price!
sanpablo
Rich
Long Island, NY
My local Walmart has the H4 AGM in stock but they all have a 3/25 sticker on them. All the other batteries are within month or so, 12/25-1 /26. $139 (US)
JT Maverick
New Jersey
Both $95/535CCA (see photo) and $189/570CCA versions feature 4-year free replacement warranty (no diff in that regard).
JT Maverick
New Jersey
$95/535CCA version seems to be available online only (link in message #36 above).
Free shipping with same or next day delivery (in my case at least).
uga
SE USA
2026 Ford Maverick XLT
I think you got the deal of a lifetime, I called my local Walmart Auto Center and they laughed at that price for an AGM battery.
JT Maverick
New Jersey
As stated all along, online only. Appears to still be available (I see that if I ordered one now I would receive it tomorrow with free shipping to home address). Link I provided in message #36 above works for me.
710-oil-614
Cal
That’s not what your link showed. Just a 3 year warranty but obviously the sticker is different.
uga
SE USA
Shows out of stock here locally in Georgia, not available at any store in this state.
Great for you but not sure anyone else has been able to take advantage of this deal. Maybe a local mistake ?
JT, Click on the envelope in the bar above to the right for a message........................
710-oil-614
Cal
It ships for free....
JT Maverick
New Jersey
Clicking on the link I provided in above messages #33 and #36 (where I say "This should work: ") results in something different? Strange, that link still works for me with the battery still available for delivery to my home tomorrow. As stated originally, there are some inaccuracies/minor discrepancies (keep in mind it's Walmart Online) and no image of the $94.92 535CCA AGM battery is provided. The listing indicates a 4-year warranty (Platinum-level feature?) but I do also see a reference to 3-year. For that matter, I also see an incorrect indication that "It looks like it doesn't fit my '23 Maverick XLT Hybrid" and some other incorrect or at times conflicting references. Simply sloppy. All mentioned before. I don't see anything in Walmart's online listing today that is different from when I purchased mine in November. Photos of the battery I received show exactly what I received and the fit and all were perfect. Of course, if what I received was different or wrong, I was simply planning to return it to my local Walmart (viewed the ability to do that as one of the many pluses).
If the previously provided link isn't in fact working, while using Walmart online and searching for "
EverStart Premium AGM Lead Acid Automotive Battery, Group H4" I come up with the following (here image only - not clickable) which includes the selectable $94.92 535CCA AGM battery (along with others). Try doing that search.
uga
SE USA
Tried my local Walmart after signing in, no luck, not available for shipping and not available fpr pickup anywhere in Georgia.
Thanks JT for the help. Maybe that was a early Black Friday deal up by you last November. Glad you were able to score that deal for your Maverick
