How to reset Oil Change light?
SWFLGulf
Naples FL
So while I had my truck in for the airbag recall-which didn't happen-I had them do an oil change and tire rotation since it was just 100 miles short of the recommended mileage. Now when I start my truck, I get the reminder that an oil change is needed. I guess the tech didn't reset it. Does anyone know the procedure to reset it without going back to the stealership? Thanks in advance.
JBryant
Jesse
Bowie, TX
I am sure it is different, but a lot of vehicles would have you turn on key, open door, go thru hoops, say two poems and three Hail Marys, and that is just to get you started. That's another reason why I do not do my own oil changes.
I would just call the dealer service department and they can tell you.
Nosehtam
Jeff
Washington
93 Ford Escort
You can reset it through the menu. Menu to settings, vehicle and then scroll down to oil life.
Zotman
Detroit suburbs
Lariat Lux Hybrid, Focus
Page 304 of Owners Manual:
SettingsPress the OK button, then from this menu scroll to the following message.
Oil Life ResetPress the OK button, then from this menu scroll to the following message.
Hold OK to ResetPress and hold the OK button until the instrument cluster displays the following message.
Reset Successful
When the oil change reminder resets the instru- ment cluster displays 100%.
Remaining Life {00}%
If the instrument cluster displays one of the following messages, repeat the process.
Not Reset
Reset Cancelled
SWFLGulf
SWFLGulf
Naples FL
Thanks everyone. I made sure have the latest software version but when I go to SETTINGS, there is no OIL LIFE RESET. I have INFORMATION; DISPLAY; DRIVERS ASSISTANCE;VEHICLES SETTINGS and MY KEY. I went under each of those. Nothing about OIL LIFE RESET.
SWFLGulf
SWFLGulf
Naples FL
OK I found it! During my search when I hit OK under INFORMATION, it showed only TRAILER LIGHT STATUS. Turns out that is the last item on that sub menu. I toggled up and found the oil reset along with MY KEY INFO, SEAT BELTS and other settings on the 1st page!
Again, thanks for the help. This is why I like this site. Always help around when you need it.
billbillw
Metro Atlanta
'23 Maverick Lariat FX4
Makes you wonder if the stealarship actually changed the oil...
Did you look to see if its a new filter? Check the color of the oil?
SWFLGulf
SWFLGulf
Naples FL
Yup. Thats the 1st thing I did before I started to get the oil change reminder. I had a bad purchase time with the dealership. Only reason I let them do the oil change & tire rotation was the truck was going to be in there for the airbag recall- which didn't get done.
