How do I know if my maverick has a rain sensor?
Grammaton
Ross
Covina, CA
2023 Ford Maverick AWD Lariat BAP 4K CP360+Assist
Cancunbadlands
Cancun
Cancun
WTF is a “courtesy wipe” on my dash menu? On or off, no difference! That I can tell anyway.
When you spray your windshield, the wipers automatically run a few cycles to clean off the liquid. However, a few seconds after they stop, a single "extra" wipe occurs. This is the Courtesy Wipe, meant to catch any leftover fluid that often streaks down from the top of the glass after the initial cleaning.
I think if you have a lane keeping assistant it wipes your windshield to keep the sensor clean.
USING THE WINDSHIELD WASHER
Ford Maverick How do I know if my maverick has a rain sensor? 636895042_10231695073539685_1213955125389028609_n
Pull the lever toward you to operate the windshield washer.
Note: A courtesy wipe occurs a short time after the wipers stop to clear any remaining washer fluid when switched on. See Switching the Courtesy Wipe On and Off.
Darthie
Darthie
Frank
2023 Maverick Tremor, 2016 MB AMG GTS
Is that what they call it. Like the courtesy flush on yearnals.
Tinman55
Iowa
2025 Maverick XLT
I myself would be leery of anything that involves a cable that piggy backs off another cable. I would hardwire it to the fuse panel and have the device have its own fused circuit.
samspritzer
Sam
Buffalo NY
2019 CRV
Ford is conscious of those with OCD and need to make sure the windshield is wiped clear of every single excess drop of water. If you click yes, your OCD should last no more than 3 seconds every time you want it to clean the windshield. Please keep in mind you should keep a couple of jugs of windshield washer in the trunk in case you run out.
