Horn blows
When I stop at the mailbox, put truck in P, unbuckle seat belt, open door, get out to get mail if I close the door it double honks with fob in my pocket. If I leave door open with fob in pocket silence. I assumed (yes I know what that makes me, I won't infer it does the same to you :ROFLMAO: ) it was to alert me that I left the vehicle running and exited the vehicle. It seems to be programmed that if the door remains open to think you are coming back.
If you lock the truck with the fob or the key pad you can go to mailbox with the truck running. Or go into store or whatever. I don't remember if it will shut off after the max idle time whatever you have that set at expired.
Ah - so opposite of what I said.
If fob is left in the cabin and you open door and close it and it honks - it thinks fob got out.
So Cherokee has correct response.
Now if it would just toot when you've locked the door and gotten out closing door - so you can start early trying the back doors or calling someone or remote unlock.
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
Thanks for that information but NEVER will I leave my vehicle running while I am in a store, post office etc. And I have no need to lock it in my driveway while I get the mail from the back side of the box. Now if I still had the hand crank started Model T I might :crackup:
My long deceased brother left his car running, he carried a spare key in his pocket, while he went in to buy more beer. This was back in the day before double honks, seat belt pop ups, and cars still had the lock knob at the top on the inside of the door. He starts BS'ing with the clerk who he knew well and is in there about 15 minutes. He comes out to find his car gone. So I turn off my vehicle when I am going into a business and lock it with the fob so I know the fob is indeed in my possession.
MavStangVa
2024 LARIAT AWD
I'm confused. If I leave the fob in the cabin, get out, lock the door using power switch on door and I want it to honk at me. All Cherokee said was it double honks with fob in pocket to which I agree mine does also IF the truck is running and door is shut, not locked at all.
Does yours honk whenever you leave the cabin with the fob? Mine will single honk to show I locked using the fob with a double tap but not with the auto lock on the door or single tap of the fob.
I got no keyless entry.
Ya the honk with fob in cabin and attempting lock all gets the honk and all unlocked.
That's been the very known effect whenever auto-lock key in truck confusion comes up.
To your point where you both have the same experience - fob leaves with door getting closed. I never said locking was part of it - neither did either of you.
That's the new one for me.
So my point was the effect of confused sensors - which I've seen a couple posts on - the correct problem is if you close door and fob is in truck, no locking, and it honks - it thought the fob left.
Because if sensor was correctly pointed - you should be able to close door with fob in cabin.
You have a misadjusted sensor.
It thinks the fob is still in the cabin.
Still within 3 yrs/36k warranty?
And are you shutting door with finger on handle sensor requesting lock all function?
I don’t know. I’ll likely forget about all this next service, no biggie.
The shift knob will stay in park position until the fob(s) that were not in truck when truck was locked OR the keypad IS is used to unlock it. I usually only lock my truck running when it's in my driveway or garage and want to charge my 12v for an hour or two without bothering to put noco onto jump pins.
What model norco charger are you using?
MavStangVa
2024 LARIAT AWD
I would think with the price of gas that it would be more economical to use the charger. I have an EB so no need to let it run in the driveway other than to heat up the oil and cool off the cabin. I will remote start by hitting the lock button, remote start button, then unlock button and put the fob in the pocket. I know the auto unlock handles will unlock it but old habits die hard :ROFLMAO: .
MavStangVa
2024 LARIAT AWD
I noticed no replies from the OP.
In the interest of science or curiosity I decided to do a @Glen Baker LLC research project into what conditions my 2024 Lariat honks.
Remote started using the fob from 20 feet away, no honks. Unlocked with fob same distance no honks.
Backed into the turn around in driveway , truck on, fob in pocket, exit truck, door open, walked 12' away, no honk.
Closed door, walked away, double honk.
Truck running, fob in cabin, door open, no honk.
Truck running, fob in cabin, door closed, no honk.
Truck running, fob in cabin, pushed lock button on inside of door, double honk.
Truck running, fob in cabin, touched autolock on outside of door, no honk and no locking.
Truck running, fob in pocket, hit lock button on inside of door, locks, unlocks instantly, double honk.
Truck running, fob in pocket, touch auto lock on outside of door, locks, no honks.
Now I can sleep tonight 🤣
What NO Video😱
What about the magical camouflaged lock lever??
That little lever has "Automatically" locked more owners out of there trucks. Some were unaware the lever was even there
We won't mention that the other three doors were still unlocked😁
Good job👍👍
MavStangVa
2024 LARIAT AWD
What NO Video😱
That little lever has "Automatically" locked more owners out of there trucks. Some were unaware the lover was even there
Good job👍👍
I have never mastered doing videos on my phone. And I got rid of my old 300# vhs camcorder years ago 😂
BillHanna
Cana, Virginia
2024 Maverick XLT, 2020 RAV4, 1975 Corvette Stingray
If you open the door, then hit the lock button (in front of the handle), the horn will beep twice. Did it a few times by accident.
@mavstrangva
I knew Glenn was going to ask you to show your work, not just the answers.
So there is a setting for Feedback for horn response (not the mislock option).
I think the double-honk warning will happen anyway in what you showed.
But some of the others may be different.
Just for completeness - what is your setting on?
Ford Maverick Horn blows IMG_20241120_092308226_HDR
