Highway MPG for hybrid Maverick?
j9thompson
Jeannine
Bay Minette AL
Chevy Equinox
I keep seeing 40mpg in the city for the hybrid. What is the on the road mpg? I drive over hundred miles a day for work so most of my time is interstate travel
  • Like
Reactions: Doc
dp4616
Daniel
Sunrise, FL
2011 Ford Ranger
Still no info on 2.0l though? I drive mostly highway so if it’s close to 30+ might opt for it.
  • Like
Reactions: Doc
FirstOnRaceDay
Devin
Toledo Ohio
2000 Mercury Grand Marquis LS
It’s the same system as the bronco sport badlands. But since it’s a truck it will get SLIGHTLY worse mpg.
AWD 2.0 bronco sport gets 21/26/23
My guess for
2.0 AWD w/ max towing is 20/25/22
Ma
2.0 AWD w/o max towing is 19/26/23
2.0 FWD 19/27/23
dp4616
Daniel
Sunrise, FL
2011 Ford Ranger
Well at 26 highway I’ll still grab the hybrid then. 2k towing is more than enough for my small popup camper.
  • Like
Reactions: Doc
Oakland
Georgia
Ford
Off topic, but since the hybrid is being discussed, does anyone know what the warranty is going to be on the battery. I can't seem to find it anywhere.
balucipher
Balu
Coral Springs, FL
2011 LX570, 2021 Tesla Model Y
https://help.ford.com/warranty/hybrid-electric-vehicle-unique-component-coverage/
8 years/100,000 miles (whichever comes first)
Depending on your vehicle, electric drivetrain system components covered by this warranty may include, and are not limited to:
• High-voltage battery
• High-voltage battery connector
• High-voltage battery isolation switch (manual disconnect switch)
• Battery pack fan assembly
• Battery pack sensor module HBPSM)
• Battery energy control module (BECM)
• On-board charger
• On-board charger fan assembly
• Inverter system controller (ISC), DC/DC converter
• Hybrid continuously
• Variable transmission
• Transmission range sensor
• Electronic drive module assembly (the electric motor and gearbox).
If an electric drivetrain system component requires replacement under warranty, it may be replaced with a new factory remanufactured, or factory refurbished component, at Ford’s discretion. Refurbished battery components selected for your vehicle will align with your vehicle’s age and mileage, and meet Ford’s stringent requirements and standards.
For important warranty details and exclusions, contact your dealer or see your Warranty Guide.
High Voltage Battery Gradual Capacity Loss
The high voltage battery will experience gradual capacity loss with time and use, similar to all batteries, which is considered normal wear and tear. Loss of battery capacity due to or resulting from gradual capacity loss is NOT covered under the New Vehicle Limited Warranty.
See your Owner’s Manual for important tips on how to maximize the life and capacity of the high voltage battery.
