Hopefully I can get to the install after dinner today. Looks easy peasy.
t
Does the Tee harness go in the dome light?Well f••k not getting power. So frustrating. Grrrrrrrro
I see it connects to what they refer to as the "lane keeping assist" or "rain sensor" connector. Obviously you have the connector, but does your truck have that feature and are those pins powered?Well f••k not getting power. So frustrating. Grrrrrrrro
From the Dashcam's site:
Resolution (If your truck has an Lane-Keeping Assist's 12-pin connector, it can plug and play for power, otherwise it needs to connect power from the fuse box or OBD.)
I have lane keeping yes. That’s the connector it splices into.
Here's one review: The 2024 Ford Maverick Hybrid Lariat does NOT have the rain sensor in the equipment box above the rearview mirror. You'll need to route it to the fusebox which is totally do-able even if you've never opened it up before in your life.
Good luck...
It goes to the lane keeping module not the lightsDoes the Tee harness go in the dome light?
That light's voltage depends on brightness adjustment I seem to remember.
No mavericks have rain sensors.
Good luck...
No it does notDoes the Tee harness go in the dome light?
OK, I do see on the fitcamx site that's where the tee harness connects.It goes to the lane keeping module not the lights
Could I possible have it plugged in wrong. Seems like there is only one way to do it? Maybe I popped the fuse? GrrrrrrrOK, I do see on the fitcamx site that's where the tee harness connects.
It's the connection in my post #5 above.
Lane Keeping/Centering System works off of the Forward Collision Camera / IPMA / CCM radar and does have 12 volt power on 2022-2024 Mavericks.
So the fitcamx tee harness should be sending power to the dash camera.
It's the same place I have my tee harness plugged into that powers a comma.ai. 3X.![]()
edit.
Yes I had the car running. Is there supposed to be I light on the camera so you can see its on?It appears he should be able to probe the back side of pin 4, (Violet/Gray), for +12VDC and insure he has power into his harness cable and camera... Not looking at mine, I suspect it's the wire highlighted....
OP, you have the ignition on and engine running?
RIght only one way to plug it into the IPMA.Could I possible have it plugged in wrong. Seems like there is only one way to do it? Maybe I popped the fuse? Grrrrrrr
