Here's my new Dash Cam.
Darthie
Frank
Hopefully I can get to the install after dinner today. Looks easy peasy.
Ford Maverick Here's my new Dash Cam. IMG_0664
t
Darthie
Darthie
Frank
Well f••k not getting power. So frustrating. Grrrrrrrro
BlueSpec1
Gene
Does the Tee harness go in the dome light?
That light's voltage depends on brightness adjustment I seem to remember.
Johnkn
MD
I see it connects to what they refer to as the "lane keeping assist" or "rain sensor" connector. Obviously you have the connector, but does your truck have that feature and are those pins powered?
From the Dashcam's site:
Resolution (If your truck has an Lane-Keeping Assist's 12-pin connector, it can plug and play for power, otherwise it needs to connect power from the fuse box or OBD.)
Here's one review: The 2024 Ford Maverick Hybrid Lariat does NOT have the rain sensor in the equipment box above the rearview mirror. You'll need to route it to the fusebox which is totally do-able even if you've never opened it up before in your life.
Good luck...
BlueSpec1
Gene
If the harness is for Forward Collision Camera / IPMA, all 2022-2024 Mavericks have it at the front windshield.
22-24 Maverick Camera: IPMA Module - Connector C9039
Ford Maverick Here's my new Dash Cam. 1773116015129-nn
Darthie
Darthie
Frank
I have lane keeping yes. That’s the connector it splices into.
Good luck...
Darthie
Darthie
Frank
It goes to the lane keeping module not the lights
Darthie
Darthie
Frank
No mavericks have rain sensors.
Good luck...
Darthie
Darthie
Frank
No it does not
Maverick123
Waiting
there are sellers on Ebay or Etsy that offer harnesses to get a 12v or USB-C output out of the wiring in the upper windshield camera housing. Would be an easy plug & play ...
BlueSpec1
Gene
OK, I do see on the fitcamx site that's where the tee harness connects.
It's the connection in my post #5 above.
Lane Keeping/Centering System works off of the Forward Collision Camera / IPMA / CCM radar and does have 12 volt power on 2022-2024 Mavericks.
So the fitcamx tee harness should be sending power to the dash camera.
It's the same place I have my tee harness plugged into that powers a comma.ai. 3X.
Ford Maverick Here's my new Dash Cam. 1773112670584-j1
edit.
Ford Maverick Here's my new Dash Cam. 1773113964780-dc
Johnkn
MD
It appears he should be able to probe the back side of pin 4, (Violet/Gray), for +12VDC and insure he has power into his harness cable and camera... Not looking at mine, I suspect it's the wire highlighted....
OP, you have the ignition on and engine running?
Ford Maverick Here's my new Dash Cam. 3gtc0H
Darthie
Darthie
Frank
edit.
Could I possible have it plugged in wrong. Seems like there is only one way to do it? Maybe I popped the fuse? Grrrrrrr
Darthie
Darthie
Frank
Yes I had the car running. Is there supposed to be I light on the camera so you can see its on?
BlueSpec1
Gene
RIght only one way to plug it into the IPMA.
Popped fuse to IPMA should result in a bunch of errors popping up on Instrument Cluster.
