Dash cam installed
clavicus
Are you super sure that USB/12v socket is truly battery constant, or might it just be delayed like how some accessories don’t actually turn off until you turn off the engine, open the door, close it, and lock. Or some have a 30 min delay?
Fuse #3 and #6 are the only micro2 fuses that are ignition-only power, but the first three micro3 fuses in the lower-left of the panel are also ignition only. I’m going to try one of those this weekend if I get my parts in and the weather plays nice.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
In one of my cars I wired a switch to the cig power so I could turn it on/off.
  • Like
Reactions: Dad
Dad
Good point. Let us know what you find out.
g1zstar
NY
XL Hybrid Barebones
If that's the case, what would be the advantage of hard wiring it?
It'll stop pulling power power when the battery drops below a certain voltage.
The 12v kept my dashcam on for about an hour and 15 minutes, then the battery presumably died. (Last dashcam clip was less than the 3 minutes so it was interrupted)
But on the other hand other nights previous to my dead battery night, the 12v only kept the dashcam on for about ~30-45 minutes.
So not entirely sure what's going on there.
No shenanigans with the usb slots so far.
Dad
Did your battery die or did the vehicle automatically shut down its electrical system?
g1zstar
NY
XL Hybrid Barebones
It died, or at least was dead in the morning when I got to it.
Dad
That's very odd. Most cars shut down their 12v systems when you turn off the ignition or at least within 5 minutes. I had a mysterious dead battery on my previous truck only to discover my daughter left on the rear seat lighting all night. Too difficult to detect with the tinted windows.
Mymaverick2021
Steveo
Hilo Hi
I installed my dash cam a couple of days ago, using the power socket in the lower, center part of the dash.
Today, I realized that unlike the other two vehicles I've owned, where I installed a dash cam, the Maverick's power socket stays 'hot' when the ignition is off.
That means the dash cam stays on all the time.:mad:
I could pull the plug out each time I leave the vehicle, which is a real pain, or I could hard wire it in (something I'd rather not do).
Anyone have any other solutions?
You could splice in a on/off switch but wouldn't be easier to just unplug it 😉
Dad
I haven't gotten my Maverick yet, but on my focus I use a very small Garmin dash cam which is connected to the USB port just below my radio. It comes on when I start the car and goes off when I turn the car off. You can hardly even tell that I have a dash cam. Very happy with it. Ran the wire just under the headliner under the weather stripping on the door, under the dash where the excess wire resides and goes to the USB port. Almost invisible. I was going to hard wire but this was so much easier ;)
Do you not lose the parking monitor ability of the dash cam?
rognus
Roger
Northern Nevada
2025 Ford Maverick XLT Hybrid AWD, Subaru Impreza
Unfortunately, the USB port, which is located right beside the large power socket, is also 'hot' all the time.
My USB port isn't hot all the time? I turn off my hybrid, my dash cam goes off. I turn on my hybrid, the dash cam comes on. It's installed and working with no hitches.
Jasperw229
Jasper
Portland oregon usa
Maverick 22, Lariat fx4, 4k tow
I hardwired a viofo a129 using a kit they sell. Along with a piece of coat hanger and some electrical tape it went pretty well.
It tells the camera when the acc circuit turns off and switches itself to parking mode.
This is lower power usage and seems to last at least 12 hours without the camera shutting off.
On a side not my truck never shuts off the engine anymore for auto start/stop. I checked the battery and it was 12.66v which seemed perfectly fine to me. The truck apparently isn't happy with that voltage and keeps the engine running to charge itself.
My driving habits put me at just over 1 hr of driving time and 23 hrs of parked time per day.
Deacon Blues
Ron
British Columbia
2017 Honda Fit, 1997 F150
Then the USB power supply is different between the hybrid and eco boost Mavericks, because when I used my USB plug to power my dash cam the camera stayed powered when the ignition was turned off.
I also checked the USB outlet with another device and found I could get power to that device with the ignition off.
Paul Stovner
Paul
Long Beach Calif
Mazda CX5
On my 2023 Maverick the Power Socket (12V) and the USB sockets shut off automatically, but it's a long 4 minutes after you shut off the vehicle. So you might want to re-check?
