Gorilla lug nuts compared to OEM…
JPinPA
Jay
Stewartstown PA
2024 Maverick XLT
Good day everyone, I was about to swap lug nuts and after removing the first one I compared the two and noticed the difference in their profiles.
I’m now in a quandary as to what to do. I’m sure this swap has been done by members. Any input on this?
Ford Maverick Gorilla lug nuts compared to OEM… IMG_2902
Ford Maverick Gorilla lug nuts compared to OEM… IMG_2906
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
Do the gorilla specs indicate conical seat. Should be 60 degrees
JPinPA
JPinPA
Jay
Stewartstown PA
2024 Maverick XLT
Yes, 60 degree seat, but not enough of it.
I found a thread from last year commenting on the same issue. Doesn’t look to have settled on the issue with any follow-up.
There’s been lots of threads in past on lug nuts, search this forum you’ll find them, I seems to recall it can depend on the different wheel styles. Good luck
JPinPA
JPinPA
Jay
Stewartstown PA
2024 Maverick XLT
@Lynyrd Skynyrd
Did you ever resolve your issue with the after market lug nuts from last year? I’m just finding the same issue.
JPinPA
JPinPA
Jay
Stewartstown PA
2024 Maverick XLT
After some digging around I was able to find that
After digging around via a Google search I found the suggested part number for the Maverick should be:
https://www.google.com/search?q=gor...2ahUKEwi8ztv177qGAxWxKFkFHThHAm8Q8I0IegQIFxAC
AzureBlueBill
Torrington, Connecticut
I can't see what difference it makes. That taper matches the taper on the wheel. I've been using smaller nuts like the ones you show on multiple cars for decades. Matter of fact Tire Rack even supplied that smaller type nut to me when I bought wheels/tire from them. On the truck now. I haven't had one nut loosen. Checked torque twice now.
Fibrepunk
2023 Ford Maverick XLT Hybrid
I replaced the ford lug nuts with Gorilla 61148CX - Black and a set of Gorilla 96641BDX for locking.
Lobster1960
Ron
2024 Maverick Tremor
You should look for Gorilla pt#96643BDX
Sticks
Shawn
St. Louis
A smaller contact patch results in higher pressure exerted on the wheel by the nut. Higher pressure means there's an increased chance of fracture. It's safer to use a nut that's designed for an OE wheel on an OE wheel (In theory, anyway).
Aftermarket wheels are typically designed to use the narrower seat, so they (in theory) would be made to handle higher pressures on that surface.
JPinPA
JPinPA
Jay
Stewartstown PA
2024 Maverick XLT
Thank you for the (mostly) helpful replies and advice.
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
Will those gorilla lugs work with bronco sport big bend wheels?
