Gorilla lug nuts compared to OEM…
Hot Runr Guy
West Chicago, IL
Will those gorilla lugs work with bronco sport big bend wheels?
Since the BS wheels are sized to use 12mm studs, you don't need the "bulge" style with the extended taper, as it won't be in contact anyway.
HRG
hdave
Toronto, Canada
'23 Alto Blue Maverick XLT
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
Exactly what I went with!
Looks good. You’ll have to keep us posted on how the black coating holds up to chipping and whether these rust.
I want these but $180 in Canada. $150 CDN if I buy them in the US. A lot of money if they just end up rusting like the ones I bought off Amazon
AzureBlueBill
Torrington, Connecticut
2024 Maverick Lariat / 1998 Mustang Cobra
A smaller contact patch results in higher pressure exerted on the wheel by the nut. Higher pressure means there's an increased chance of fracture. It's safer to use a nut that's designed for an OE wheel on an OE wheel (In theory, anyway).
Aftermarket wheels are typically designed to use the narrower seat, so they (in theory) would be made to handle higher pressures on that surface.
Have you ever seen a wheel that fractured becuse of this lug nut issue? I've never heard of it.
AzureBlueBill
The Gorilla nuts are cheap and will not hold up to any kind of road salt. I'm sure if you lived in the southern US instead of Canada, they might not rust .
ryan2366
Ryan
I should clarify, like the non gorilla ones I bought off of Amazon.
Don’t buy these ones.
https://a.co/d/4lNNgC3
EONR24
Swag
United States
2024 Ford Maverick XL
50k miles and 6 years on my focus st in Ohio and the gorilla lug nuts are still black, no rust or damage. OEM lugs are much lower quality than gorilla lugs. There are some other good brands besides gorilla as well but gorilla lugs are not cheap. OEM lugs are cheap. The caps eventually get seperated on the OEM FORD lug nuts from using and impact to tighten/loosen them
AzureBlueBill
I agree, the OEM nuts are garbage. I've never had great luck with Gorilla nuts. I like McGard. To each his own.
