Getting a lightweight travel trailer!
Derwood
Derwood
Buick and Kia
Got a lucky score in this vintage early 70s 1100lb trailer! Even with a few hundred lbs of gear will be well under the 2,000lb towing capacity for my Maverick hybrid. Am sooo looking forward to get out camping again!
EDIT: Naturally the suggested mode is tow/haul. I'll be on relatively flat surfaces for most of my trip home with the trailer this weekend. Not worried about gas mileage but is there any benefit to the transmission (most important to me IF it would help) or engine to use ECO or Normal mode while towing?
EDIT
Ford Maverick Getting a lightweight travel trailer! 1729478325163-x3
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
1200lb trailer, plus 40lbs of propane (2x20lb tanks I see there), water? (another 100+lbs), a few hundred pounds of gear? Yeah you will hit the real 1500lb limit (use the Ford towing calculator) for towing fast. I hope it works out and doesn't have leaks!
BeachFerret
Third
Not a Maverick
Nice! Looking Forward to an update when it’s further along. Cheers.
The Real Maverick
Jack
Got a lucky score in this vintage early 70s 1200lb trailer! Even with a few hundred lbs of gear will be well under the 2,000lb towing capacity for my Maverick hybrid. Am sooo looking forward to get out camping again!
I think you'll be fine.
Keep in mind tires are good for only about 7-8 years. The rubber rots, even if the tread looks good. Make sure the trailer has good tires.
Pull at any safe speed that keeps the power needle under 50% and you'll be fine.
Blinky
Alberta, Canada
Total weight on a full 20 pounder is closer to 53-59 pounds but you're right, weight creeps up real fast when adding camping gear.
Packing light isn't just for backpackers, it's equally important when dragging a trailer, most people I know way way over pack for camping trips.
Strongly suggest you carefully check over the trailer wiring, probably replace tires, and re-grease the hubs/bearings. Other than a blow out nothing ruins a trip faster than an overheating wheel bearing, especially if you don't catch it before major damage has been done.
Derwood
Derwood
Derwood
Buick and Kia
I am def going to check all that. Seller says he's taken care of those things but will still look for myself.
Derwood
Derwood
Derwood
Buick and Kia
I'm guessing you'll be well over the 20 sq/ft frontal area limit?
HRG
The truck itself hides a lot of the frontal area of the trailer but I'll be taking it easy no mountains or huge hills mostly flat land.
Derwood
Derwood
Derwood
Buick and Kia
Going to keep gear to the absolute essentials only. Not my first rodeo with a travel trailer and have been looking to get back into it. Won't be any stupid long trips nor any mounta
Sorry my math stunk there. Lol. The trailer is listed empty as 500kg which is only 1,100lbs not 1,200lbs. Won't be carrying much water tank is only five gallon full propane tanks are another 120lbs or so. That'll leave me leeway for gear and I'll still keep below 1,500lbs total weight to be on the safe side. Mostly short trips are planned. No mountains or long stretches of up and down hills around me it's pretty flat in S. Ontario.
Johnny maverick
Nh
Frontal area affects the towing ability mre than everyone realizes. I never really thought about it . It wasn't a factor with every truck I've ever owned. I just towed my toys back this weekend from lake. 20' tritoon, 4x8 inclosed motorcycle trailer , 18' checkmate v8 IO.and 13.5' funfinder camper. It's a 80 mile trip each way. Each time up I got 28 29mpg. 3000lbs Pontoon got 12.5mpg. The 4x8 didn't even know it was there. The 3000lbs checkmate I got 24mpg. And the 3000lbs funfinder got 13.0mpg. My last trip back My friend in his 23 F550 crewcab was towing his 12k escavator on a flat bed. And he got 15mpg.
Ford Maverick Getting a lightweight travel trailer! 20240422_110641
Ford Maverick Getting a lightweight travel trailer! 20240708_194339
Ford Maverick Getting a lightweight travel trailer! 20240526_110030
Ford Maverick Getting a lightweight travel trailer! 20240825_150401
Old Fart
Mid Florida
2022 Ford Maverick XLT; 2016 Prius ECO
Ford Maverick Getting a lightweight travel trailer! IMG20240829085922
We started towing this with a PriusV last weight in was 1150# worked a lot better when it went up and down but I'm tired of working on it, set up is pretty fast now.
OB1e
Massachusetts
CG LUX XLT
Did you snag it for free?
CajunMick
Heman
Houston, Texas
2023 XLT Maverick
Ah, a Lucy n Desi trailer.
Be sure to select Tow Mode when you do tow.
Have fun.
TennesseeVic
Victor
Tennessee
2024 XL Maverick
Tangent: thinking of getting an aftermarket tow package installed on my 24 hybrid XL. Would I still use the same limitations e.g., 2k lbs, as if it were a standard package?
LGM30G
Doug
2024 Lariat Hybrid
Some campgrounds won't accept campers over 10 years old.
