Gear display in the instrument cluster
bdaniel230
Daniel
Middleton, Id
2022 Ford Maverick XLT -Hot Chili Red - 4k Tow Fx4
I meant which of 8 gears ahead. There are some possible settings using FORSCAN to display that. I will try.
Let us know what you find. I have often wanted to know which gear I am in when I am off-road
NJBob
New Jersey
My F-150 has that. It's nice to know what gear you are in. Don't think the Maverick has that.
maccobra
Keith
Atlanta, Ga.
2024 XL FWD ecoboost
I’d like to know also. Do any of the tuners show that?
TORQUERULES
Ford
In for this. It's frustrating not knowing what gear it's in.
Toddman45
St. Louis, MO
I doubt the Maverick has the capability to display it.
Jtitzer56
Evansville, IN
Lariat AWD EcoBoost
The gear display can be turned on through tuning with an accessport. I have an explorer cluster in mine but I know the base and Lariat clusters can show the gear when manually shifting after adding paddle shifters, so they should be able to show the gear all the time.
Ford Maverick Gear display in the instrument cluster IMG_20250109_163024
EONR24
Swag
United States
2024 Ford Maverick XL
I have not found a way to add gear display only using Forscan codings. Yeah if you add a steering wheel with paddle shifters and make the necessary forscan changes, you can display the gear you are in on the instrument cluster. The Cobb Accessport can also display what gear you are in. You can use OBD fusion and a OBD reader to display it on your radio screen as well.
diegoborges
Diego
Brazil
Ford Maverick Tremor
hi guys !
I strongly believe that i found some important information on this subject ! but somebody needs to test it and return here to say if it works or not !
thanks !
Target Gear Indication (TGI) • Gear Range (GR) • Gear and Range Display L0 (GRDL)
720-09-01xxx*xxxxxx--0 =TGI disabled • GR 6R • GRDL disabled8 =TGI enabled • GR 6R • GRDL disabled
1 =TGI disabled • GR 6R • GRDL enabled9 =TGI enabled • GR 6R • GRDL enabled
2 =TGI disabled • GR 10R • GRDL disabledA =TGI enabled • GR 10R • GRDL disabled
3 =TGI disabled • GR 10R • GRDL enabledB =TGI enabled • GR 10R • GRDL enabled
4 =TGI disabled • GR Not Used • GRDL disabledC =TGI enabled • GR Not Used • GRDL disabled
5 =TGI disabled • GR Not Used • GRDL enabledD =TGI enabled • GR Not Used • GRDL enabled
6 =TGI disabled • GR Not Used • GRDL disabledE =TGI enabled • GR Not Used • GRDL disabled
7 =TGI disabled • GR Not Used • GRDL enabledF =TGI enabled • GR Not Used • GRDL enabled
Gear Display Mode (GDM) • ECU Architecture (ECUA) • Fleet_Flash_Brake_TT_Cfg (FFBTTC)
720-11-01xxxxx*xxxx--0 =GDM disabled • ECUA CGEA1.3 • FFBTTC disabled8 =GDM enabled • ECUA CGEA1.3 • FFBTTC disabled
2 =GDM disabled • ECUA CGEA1.3 • FFBTTC enabledA =GDM enabled • ECUA CGEA1.3 • FFBTTC enabled
4 =GDM disabled • ECUA FNV2 • FFBTTC disabledC =GDM enabled • ECUA FNV2 • FFBTTC disabled
6 =GDM disabled • ECUA FNV2 • FFBTTC enabledE =GDM enabled • ECUA FNV2 • FFBTTC enabled
REDRUM
Central Jersey
2025 Maverick XLT
Would be nice to see what gear you are in.
Better if you have paddle shifters.
Don't see it happening from Ford.
Drove a Honda Aspencade that told me what gear I was in
Love it.
Chops
Lobo
Love it.
The Lobo has the gear display & paddles.
When in Manual Mode using the paddles - gear is always displayed.
If in Automatic Mode - the gear will briefly show if you shift with a paddle.
Just fyi. Why the Lobo is such a low volume EB is beyond me. I bought it for the lowest Maverick tailgate, but having the Ford “Select Shift” was a must have too. I think most Fords have “Select Shift” - except the Maverick & the base Mustang Ecoboost (which is a major complaint).
