"FULL" size spare not really full sized?
Nandark
Fernando
2002 Ford Thunderbird, 2018 Honda Ridgeline
Will a correct size tire fit the spare rim?
If so will it still fit in the spare tire holding area?
MattIngram
Deleteme
Deleteme
Deleteme
Its more BS. "Technically" it is a "full size", but its not the same size. I just bought new tires and bought a new matching spare tire as well. The shop that put them on didn't even want the spare they took off for free, that's how shitty it is.
Knowing how stringent people/manufacturers are with keeping the same size/brand/model tires on all four wheels of an AWD so it doesn't mess up the AWD system makes me wonder why Ford did this. They spare isn't even the same height as the others. That makes me believe Ford is OK with mismatched tires on this truck.
Just curious if you were able to re-use the spare tire wheel rim and just put a bigger size on it. I plan on doing something similar if my order gets built next year.
vezpa
EMG
IL/IN border
Too many to list.
I bought 5 new 245/65 17 tires for my Maverick, one for the spare. It fits the factory spare rim and fits under the truck.
Decayed
yes
a car
Can confirm 245/65R17 Falken Wildpeak fits under bed in spare location. I tried 245/70R17 first and it was rubbing on the front wheel wells and did not fit in the spare location.
That's good to know. I was just planning on buying the cheapest tire I could find that's the same size as what's on the truck and slapping that on the spare rim. No point in spending all the $$ on a tire that will almost never get used, but I don't want to risk getting stuck towing a trailer and having to use a half sized spare.
bradFORD
Springfield, MO
Ford Ranger
Just checked my neighbor's 2021 Chevy Colorado spare tire. Full Size Spare Tire is the exact same size tire on a steel rim.
oldfatguy
tom
1997ranger 2006 fusion 2001 bmw330ci 2004.5w3500
i installed a 225 65 17 tire on the stock full size spare rim and it worked fine and fit under the truck but there was not a huge amount of extra room.
pnorwood54
paul
ALTO BLUE XTL AWD-4K-FX4-360
any hints about putting it back on? manual not helpful, can't find a video, the one take-off video shows some nut that has to be removed from under the bed. do you replace the nut when the spare is back in place? i don't have my truck yet, thanks
Big_T
T
2022 Maverick XL Hybrid
You don't remove the nut, it stays in place. Basically, you crank the spare down and crank it back up.
csmith9058
Csmith
Ferndale Mi
This is what it looks like on the truck. The wheel weight was improperly mounted and caused my tire to go flat at 1000 miles. It looks to me like it's the same tire and steel wheel the LX comes with(?). I didn't look at the size when I had it mounted but it's definitely smaller.
Ford Maverick "FULL" size spare not really full sized? 47785
oldfatguy
tom
there is a nut that needs to be loosened / removed that is on a teather ,you have to lower the winch and remove a plastic piece and tip the end on its side and reverse to put it back , i did it on the hoist in the air and it sucked to hold the tire up in the air and replace the thing
mamboman777
Josh
NRH, TX
has anyone looked at the size of there full size spare tire , i changed oil yesterday and noticed my spare is a 215/60/17 it is about 2 in shorter than the 225/65/17 tires that are factory . i have called the dealer and thy are looking in to it , but that is not what i would call full
I think it's not same size, but full size, meaning rated for>55. Sorta silly, but I didn't change my order. It'll be nice to know that I can safely drive on the highway after I change a flat. 🤷‍♂️
Old Ranchero
CO
there is no "LX" model Maverick ;)
Barracuda340
Abilene Tx
Get the donut, then buy one of these, and a matching tire to the other 4, and have em put a TPMS sensor in it and hang it under the truck. Unless the "full size" film is already a 17x7. In which case just get an off brand 225/65R17 and install it.
Ford Maverick "FULL" size spare not really full sized? Screenshot_20220101-215226_eBay
