Full size spare comes with same factory wheel?
Wire4money
Las Vegas
2005 Wrangler
And the LUX package requires Copilot, so if you got a Hybrid LUX then you have a full spare. It's one reason I went with it.
I like eating donuts. I don't like riding on them.
No. I ordered lux, but not copilot
pxpaulx
Minnesota
It is a dooughnut on the xl and xlt unless your package upgrades it or you select it as an option
I'm pretty sure there is not a package that upgrades the spare to full size. I think the FX4 reads like it does this, but it does not. The Hybrid receives a full size spare IIRC by default, but not the 2.0 (why the engine is the determining factor...maybe has to do with how the hybrid uses braking to regenerate the battery?).
Anyway, I confirmed this with Granger and had the FS spare added for the hundred bucks - worth it even if it is on a steelie. I wouldn't be surprised if it isn't even a tire match to the FX4, but only matched by size.
SgtLip
Donald
Disney World
The Hybrid does NOT receive a full size spare by default. See the snapshot for the ordering guide, it is Optional for ALL models:
Ford Maverick Full size spare comes with same factory wheel? 1628356087567
If you order the Lariat Luxury Pkg, you have to have Co-Pilot 360 Pkg which provides the full size tire on a steely. Or you can order it as Stand Alone option.
Sliphorn
Missouri
2022 Ford Maverick XLT Hybrid
I am sure you will, but everyone needs reminding occasionally to check your spare especially if it is one of those 50-75 mile donuts. I have tried to help more people with dry rotted donuts over the years than I want to count.
They forget about them as they are not in rotation
Right you are. Out of sight out of mind. Fortunately I am the kind of guy that keeps an eye on things so I'll stay with the donut. And if for some reason I decide otherwise I'll order a full sized........though you still gotta keep an eye on it too. Such is life.
vap0rtranz
JP
Wisconsin
'22 Mav Hybrid XLT, '17 Chevy Colo Z71 diesel
My bad. Lariat LUX requires Copilot but not XLT LUX. I downgraded trims on my order, kept Copilot, and forgot which is which. @SgtLip updated the thread too.
Scooter66
Scott
Saint Augustine
2023 Bronco BaseSquatch; 2024 Maverick (murdered out)
Please forgive my ignorance again. I ordered the full size spare with my Mav. Will that come with the same wheel? This feels like a dumb question, but you never know!
No it will not. Broncos will but Maverick will have a steel wheel under the bed. So 4 wheel rotation.
vap0rtranz
JP
Wisconsin
Ford has made this confusing b/c both the trim sheet and model guides have this terrible English when describing the Copilot package:
"Full-size spare (standard on hybrid)".
Why parenthesis? Why "standard" when talking about a package when there's also a separate full-size spare option?
I used to be consulted by tech writers in my line of work. Some are great with English. Others ... aren't. This (ab)use of English doesn't clarify.
Rkbrumbelow
Robert
Cedartown, GA
HCH2, Hybrid XLT on order
It does not help when English is such an imprecise language. My field of philosophy is analytic philosophy, one of its uses is to break down language into mathematical propositions and then analyze the formal arguments. So, yes I agree wholeheartedly in both the imprecise nature of the Ford produced descriptions and with the language issue.
doug2104
JD
MD
2022 Maverick Hybrid
Its the same steel wheel that come on the XL trim model.
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
My package CoPilot selection switched me to a full size tire. I’d actually had rather have the donut due to the hassle to remove and reinstall a full size tire…10 yrs in a Ranger and never a flat. But did have to take out the full-size tire and it is not fun, donut spare is about half the weight. No matter which tire you get you have to replace the spare when you have a flat. I ended up gambling with a can of “Fix-a-Flat”, $12 electric mini-pump and removed the spare. Have had flats but mini-pump and fix-a-flat got me to a tire store.
Rkbrumbelow
Robert
Cedartown, GA
My package selections switched me to a full size tire. I’d actually had rather have the donut due to the hassle to remove and reinstall a full size tire…10 yrs in a Ranger and never a flat. But did have to take out the full-size tire and it is not fun, donut spare is about half the weight. No matter which tire you get you have to replace the spare when you have a flat. I ended up gambling with a can of “Fix-a-Flat” and removed the spare.
fix a flat is expensive because of the tyre pressure sensor if you have one installed. I’d rather see you carry a portable air pump and patch kit with a soapy water spray bottle/awl/plug which would cost the same if you ever had to use it.
if you have no pressure sensors then DWYW.
as previously stated, I carry a speed/floor jack and electric impact wrench and will buy a full sized same rim from an “auto salvage” in a year or so so I can do 5 tyre rotation
Edge Haley
Edge
CARBONDALE-Atlanta
PORSCHE
My Porsche Cayman S came with no spare but with fix-a-flat type chemical …all 4 tires have pressure sensors so I FIGURE PORSCHE FACTORY AND THEIR OWNERS MANUAL KNOWS WHAT TO RECOMMEND. Fix-a-flat is intended as a temporary/emergency fix, just like a donut tire.
There are dozens of Sport Cars today that have no spare tire…but a can of something like fix-a-flat and mini-air pump. People on motorcycles have used them for 20 years, with tire pressure sensors.
Rkbrumbelow
Robert
Cedartown, GA
There are dozens of Sport Cars today that have no spare tire…but a can of fix-a-flat and mini-air pump. People on motorcycles have used them for years, with tire pressure sensors.
Fix-a-flat the name brand claims to not damage sensors, but they will need removal and servicing. That is the specific name brand. Other brands make no such guarantees. YMMV.
source: https://www.fixaflat.com/pages/will-fix-a-flat-damage-my-tpms
I still stand by my original comments. Plus space is a substantial premium on a Porsche, and I use all of that other kit regularly (see other posts) so I will stick with a full spare, on an identical rim, with 5 wheel rotation.
the nice thing is everyone is free to do what they want.
What’s great about your post is that it shows other viewpoints and reasonings.
vap0rtranz
JP
Wisconsin
You don't need a full spare ... until you need a full spare :)
I've not had a flat in many, many years but of course it would happen when I'm hauling/towing something several hours away from AAA dispatch.
Having said all that, my Chevy Volt has a OE fix-a-flat from GM, but no owner actually recommends using it despite GM giving it to us. It goops up the tire sensors.
Rkbrumbelow
Robert
Cedartown, GA
One night I hit something on I20 about 3AM. I managed to get to a rest stop and call the local tow truck. I had lost multiple tyres and had the kind of oh my got a Rottweiler could make it through there holes in 2 tyres.
I swear to you the lady, having confirmed my location as being at a rest stop on I20 asked if I was calling from my home phone.
may reply: yes man, that’s what makes it easy to spot me I am the Honda Civic with the telephone pole sticking out the back pulling 200 miles of cable.
she did not find my reply funny at all.
