Front Storage Pocket (Dash Cubby) Use Ideas?
Dirk Dixon
Dirk
Hershey, PA
2024 Maverick Lariat Hybrid
Does anybody have any good ideas on what to use the front storage pocket next to the touch screen? Things I try to put in there fall out when I step on the gas (and No, I don't have a lead foot).
Sarah Davis
Sarah
salina, Ks
2019 Fusion, 2017 Cmax
i used gorilla double sided mounting tape to put a stitch figure in mine
Carlitos_92
🤔 Mabett sells a cubby insert. That secures into position and is removable. It has 2 storage areas. One is on the top and is concealed when the cubby is pushed in. It is pictured with the coins. The other is where the gray mat is on the bottom. Perfect size for a mini garage door opener.
The cheapest version at comes with a 17 mm ball mount along with the magnetic phone mount. I use a different phone mount and I also use the mount for my Garmin GPS.
Ford Maverick Front Storage Pocket (Dash Cubby) Use Ideas? IMG_20241209_095417
Ford Maverick Front Storage Pocket (Dash Cubby) Use Ideas? IMG_20241209_095607
Ford Maverick Front Storage Pocket (Dash Cubby) Use Ideas? IMG_20241209_095930
I have a baby Groot in there that has what a person might call an 'interference fit'.
Meaning, I jammed it in there. Doesn't fall out. :D
Random
Richmond, VA
🤔 Mabett sells a cubby insert. That secures into position and is removable. It has 2 storage areas when is concealed where I keep a couple bucks just in case the other is where the gray mat is on the bottom. Perfect size for a mini garage door opener.
I got this with the fan and it works great. I need to hide the cord a bit though.
TomBill
at home
2024 Ford Maverick XLT
Sorry this may be a dumb question, but why do you need a fan?
Ozarkbeard
I put my garage remote in there. It's attached with a removable 3M Command Strip.
Enchalada
Eli
Hawaii
Jeep Compass
second phone mount!
I use the Akros design - https://akrodesigns.com
Considered about throwing some car freshener in the void but ended up using Drift on the visors..
