Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
Decided to finally tackle the project of swapping out the front speakers and adding sound deadening to the front doors. I took mine time but overall its not a very difficult project, as some may think. This YOUTUBE video was extremely helpful for figuring out how to remove the inner door skin. Overall I used less than 20sqft of deadening material for both front doors. The outcome is noticeable with a little less cabin noise but 0 rattles.
Ford Maverick Front Speaker Upgrade and Sound Deadening Installed Photo Feb 19 2026, 7 13 11 PM
Ford Maverick Front Speaker Upgrade and Sound Deadening Installed Photo Feb 20 2026, 7 52 49 AM
Ford Maverick Front Speaker Upgrade and Sound Deadening Installed Photo Feb 20 2026, 1 01 27 PM
Ford Maverick Front Speaker Upgrade and Sound Deadening Installed Photo Feb 20 2026, 10 46 02 AM
Ford Maverick Front Speaker Upgrade and Sound Deadening Installed Photo Feb 20 2026, 1 35 53 PM
Ford Maverick Front Speaker Upgrade and Sound Deadening Installed Photo Feb 19 2026, 7 15 34 PM
Ford Maverick Front Speaker Upgrade and Sound Deadening Installed Photo Feb 20 2026, 9 52 37 AM (1)
chiko
Eric
Hampton, VA
2024 Maverick
I did the same and also found his video helpful.
One thing I thought of that I would have done differently: Use some really good suction mounts to hold the window up and slightly open. I was so nervous that I might forget, shut the door and watch the glass crash into the door.
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
I used a bunch of painters tape. My only gripe is it doesn't stick well on the areas where you push up on the window at. I was still a little nervous, but I worked quickly lol
zach57x
FL
2022 Maverick XLT
Which NVX deadener did you use?
zach57x
FL
2022 Maverick XLT
I used about 100 sq ft of this stuff and did my whole interior pretty much. Need to do a write up but man it was a pain in the ass and I don't feel like recollecting the process lol.
Ford Maverick Front Speaker Upgrade and Sound Deadening Installed 1771895492101-hc
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
Originally I was planning on using that for the door panels and using the triple layer for the outer door skins but then just decided to do it all with the same stuff. Either way it’s still better than nothing at all. I’m just happy to notice the cabin being a little bit quieter, especially since I’m on all-terrains
Toddman45
St. Louis, MO
It's not at all a fun process, but the end results speak for themselves.
MavHybtrucknotCar
Louisville, KY
2023 Ford Maverick XLT Hybrid
cyberdog
Ray
2023 Maverick Lariat Hybrid
I'd like install the install sound deadening to make my Lariat even quieter, but just hate dealing with removing the regulator, and potentially dropping the glass in the process. - It's an odd set-up for us old school owners, and I've done the deadening in three prior vehicles.
Carlitos_92
Can't speak to the Lariat specifically, but I can tell you that slathering sound mat even on the door card and the inner faces of the door (without removing the window regulator etc) made a huge difference on my XLT. I also put it on the back of the cab and inside any interior panels I removed for speaker replacement in the back, and it's a totally different truck.
notfast
Los Angeles CA
Good to know! Do the doors also shut with a nice thud instead of a slight metallic sound?
Carlitos_92
Hard to say. I'm sure it's better, but I don't think I made a Maybach for $75 or anything. I'm positive the plastic rattling and resonance when the doors are closed is reduced.
What I was really going for is less road/tire noise, and I think I accomplished that in spades. That kind of noise reduction pays off exponentially since the amp doesn't have to work as hard to give you the dynamic range you want while driving.
