Forscan information gathering thread
ryan2366
Ryan
2025 Maverick Lariat - Hybrid AWD
I would also love to have # 1
Anyone think it's possible to default lights to off ?
I've noticed they don't come on if any door besides the drivers is opened first
#2 is possible with a module
#3 is theoretically possible if you Don't mind removing slippery and tow
#2 have a look at police dark mode or silent mode.
Ford Maverick Forscan information gathering thread IMG_5170
ryan2366
Ryan
Theres been a big discussion in another thread and it seems like Canadian Mavericks do not have the option to turn the DRLs off but the USA Mavs do.
DRL’s can be turned off in Canadian Mavericks
ryan2366
Ryan
In IPC module enable daytime running lamps menu.
In BdyCM select DRL by Autolamps (vehicle) change from inoperative to enabled.
From the cluster menu select settings, vehicle, lighting, toggle Daytime running lights on or off.
Ford Maverick Forscan information gathering thread IMG_5717
Ford Maverick Forscan information gathering thread IMG_5716
Ford Maverick Forscan information gathering thread IMG_5718
Ford Maverick Forscan information gathering thread IMG_5719
Ford Maverick Forscan information gathering thread IMG_5720
Ford Maverick Forscan information gathering thread IMG_5721
Ford Maverick Forscan information gathering thread IMG_5722
Ford Maverick Forscan information gathering thread IMG_5723
You can also enable silent mode, which disables the running lights, horn and turn signals when unlocking when parked. This also disables interior lights when doors are opened. Good for camping etc.
From IPC module enable Silent mode police telltale and silent mode control function.
From BdyCM enable Silent (Dark) mode
From the cluster menu select settings, vehicle. Toggle silent mode on or off.
Ford Maverick Forscan information gathering thread IMG_5712
Ford Maverick Forscan information gathering thread IMG_5713
Ford Maverick Forscan information gathering thread IMG_5714
Ford Maverick Forscan information gathering thread IMG_5715
TopGun22
TopGun
Ontario
SONATA GL Sport
Cooool, thanks for the info.... I definitely want to quiet all these things.
I also seen its possible to quiet the chimes for door open and key in the ignition on f150 via forscan.... since all Fords have these annoying chimes, I am thinking it should be the same for the Maverick... anyone done this or know if its possible?
TopGun22
TopGun
Ontario
SONATA GL Sport
Has anyone been able to modify the number of turn signals that flash when you push the stalk halfway? It's a very popular mod to increase it from the default 3 flashes (which I feel is not enough to change lanes) to 5 or any other amount. It's well documented for F150s, Escapes, etc but the menu looks completely different on the Maverick.
Normal instructions: Forscan ford f150 turn signal mod to increase blink - YouTube
Maverick's SCCM screen:
As you can see the 724-01-01 block is completely different on the Maverick compared to other Ford products. The only other example of this I could find is from the 2020 Explorer, which someone said is apparently impossible to modify the turn signal duration on ( 2020 Explorer lane change turn signal flashes - FORScan forum ). I'm wondering if someone more knowledgeable than me is able to confirm?
Another great mod that should be able to be done since these features are driven by configed values.
Unfortunately looking at this, it in Hex and not knowing what each lines does I have no idea what to change.
Has anyone looked into figuring out the flash duration?
TopGun22
TopGun
Ontario
SONATA GL Sport
I have found several cool features that can be done in forscan on the f150 forum.
Ford Maverick Forscan information gathering thread Screenshot_20231116-232336_Samsung Internet
Anyone able to list the changes to do these ?
I have only done configuration optionss and not as built values but would love to have these confirmed for us
VicRattlehead
Mokena
Couple ford cars and a truck
where did that screenshot come from? I think it’s different than the one I’ve used in the past
(edit my link is embedding the google doc and not linking it)
That link may or may not click properly but share the link where you took that screenshot please.
JetFixxxer
Jason
Massachusetts
2023 Lariat x2, Lux, Co-pilot 360 Assist
The one you're looking at is for 2015-2020.. Topgun has the newer models 21-23. There are some differences between the generations.
VicRattlehead
Mokena
so is there no google list or excel file for the address values for changing stuff in these things???
EONR24
United States
2024 Ford Maverick XL
In addition to disabling Start Stop in PSCM easy mode, I was able to disable the Auto Start Stop button and light with this coding for the HVAC! Check coding below!
DISABLE AUTO START STOP BUTTON AND LIGHT
1. Go to HVAC AS BUILT
2. Go to 733-01-05
3. Replace the sixth digit with a "0" as shown below.
xxxx-x0xx-xxxx
4. Write the changes!
Joylove
2025 Ford Maverick Tremor
While looking at the Ford parts list for the facelift, I noted the wing mirrors that support the 360 camera are also listed as supporting folding.
Even though the button is not there on the window switch has anyone looked into what it would take to try to enable that to see if they are at least wired for folding?
Usage: RH, 11/11/2024, Maverick 2022-, Dual Pwr/Htd/Fold/App/Cam Mirror
https://parts.ford.com/shop/en/us/body/mirrors/rear-view-mirror-right-outer-p-sz6z17682d?pdp=y
