Forscan
Cvinnedge
Chuck
Virginia
2025 Ford Maverick XLT AWD Hybird
I have a Pixel 9 Pro XL phone and I can't get the Forscan App to work on it. Is anyone else having this issue? I was able to install it but get the error - "Unable to initialize application". Any advice would be appreciated.
Ozarkbeard
This may (or may not) help. Try deleting the app data, uninstalling, reboot & reinstall.
Cvinnedge
Cvinnedge
Chuck
Virginia
Thanks. I'll give it a try.
No problem on an LG device, or a prior older LG device.
Since you are on a straight Google phone, and this app is side-loaded - could there be some security/safety setting you have installed that is blocking it from running thinking it's unsafe?
Maybe even an anti-virus app running?
Cvinnedge
Cvinnedge
Chuck
Virginia
Hello all,
I fully removed it, reinstalled it, and re-entered the license and it is working now. Thanks for the assist.
Hello all,
Suggestion on selecting PIDs for display.
Many of them are available from different modules - if you can select the ones you want that happen to be from the same module, better update speed I've seen.
Suggestion on when you get the PIDs found that you want to display.
There is a Save profile or View option - for the few times the working of it hangs or a reconnect is needed - very annoying searching down the PID's again.
Cvinnedge
Cvinnedge
Chuck
Virginia
One more question - if you make changes - enable other options with Forscan - do they stay when Ford pushes an OTA update?
You have to setup the WiFi on your truck for an update to even happen.
Unless they include over the cell network - but I've yet to see the menu option that allows checking for update with wifi disabled.
Anyway, even with wifi enabled - it's only the infotainment center software that is updated.
So it's not a push as much as you set it up to check and pull. So you can disable.
And from reports - settings are saved, like they've always been.
So if doing Forscan settings in APIM - sure could have a good chance of overwritten custom info back to defaults, unless they are considered settings.
Just in case not known - Forscan Lite can't do those things, but perhaps you got the license for laptop too.
Gullzway
OK
1968 Ford Mustang Fastback
Have they changed it recently, I thought the Android app was only for viewing some information and you couldn't make any programming changes?
That is still correct.
Cvinnedge
Cvinnedge
Chuck
Virginia
I plan to get the windows version. I want to enable TSR and the other driving modes.
Cvinnedge
Cvinnedge
Chuck
Virginia
I want to view with the Android app to get familiar first before I change anything.
Ozarkbeard
AFAIK, the only updates sent OTA are for the Infotainment System. Vehicle software updates, like the ones quite numerous on early-year Mavericks, require dealer visits - either going to them or they send out a mobile tech to your home or work location. Oftentimes, these will revert all the changes you made with FORScan. Make a backup of the changes.
Cvinnedge
Cvinnedge
Chuck
Virginia
Nice to hear. Thank you.
Theoretically the Sync 4 system in 2025's may be able to.
