Itsdavebr0
NY
2024 Maverick XL
Anyone got output shots? I wanna make sure these are worth it since I drive mostly on 55mph limit back roads at night
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
Josh has some output shots in his YOUTUBE video
Jahson
MADMAN
Florida, USA
madmanmakes.com
2023 Ford Maverick (Cyber-Orange)
How the heck did you get the output to shoot that far? I recently installed mine and I just drove at night for the first time over the weekend. They only broadcast light about 20-30 feet in front of the truck. I thought I was going to hit something going home. I had to use the brights as much as I could (which work great). I tried adjusting with the adjustment screws but nothing changes. I must have turned them over 20 times in each direction and there is no noticeable change. how many times do they need to be turned in order to make any perceivable changes?
Ford Maverick Form Lighting Headlight Install headlights
TNFurb
Kelly
Nashville
‘23 Bronco Sport OB ‘24 Mav Lariat Hybrid
I admit I have not purchased or installed these, so take my question for what it’s worth. Any chance you missed reinstalling the tabs he mentions around minute 3:51 of his video?
Jahson
MADMAN
Florida, USA
madmanmakes.com
I sent an email to Form Lighting support. Their reply was rather quick, so I'll give them that.
They said "Those do look to be pointing pretty extremely downwards, and this is usually due to the adjustment assembly being detached internally, which can happen in shipping." While I'm happy with the quick response, I'm super annoyed that they didn't have some way to mitigate this if they were already aware of it being a potential issue. Or at least some kind of warning in the installation manual to check this BEFORE installation. They gave me some instruction on how to TRY to reconnect the adjustment assembly with the lamps still connected, but I was only able to get the passenger side to work. I wasn't able to fix the driver's side. I'm going to try again this weekend, but I don't think it's going to work without having to take the lamp back out. That will effing suck because the whole front bumper assembly has to be removed, which includes my fender flares that are attached in part with double-sided tape.
To be honest, these headlights are FAR too expensive to deal with this kind of preventable issue. I'm quite angry about it. But, they do look super sharp otherwise.
TNFurb
Kelly
Nashville
Wow. I can understand your anger!
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
I completely understand the frustration. At least you were able to get one of them fixed. I actually lost a low beam on my passenger side. Customer service is top notch, and I'll be getting a replacement. But now I have to wait for them to come off backorder, which could be another month or 2. As well as have to redo the whole process of removing the bumper, not bad, but annoying for sure.
Ford Maverick Form Lighting Headlight Install Photo Apr 11 2026, 3 04 34 PM
TNFurb
Kelly
Nashville
That’s actually pretty discouraging for me. I was seriously thinking about pulling the trigger. But these things are too expensive and the process to replace them is way too involved to have to deal with faulty products. I think you and Jahson have just saved me $1k 😜
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
Onc
Once they finally get caught up with orders it’ll be a lot less of an issue. I’m here to be transparent, and being a brand ambassador doesn’t make immune to having issues. So far though most people have been happy and problem free. The good thing is they fully stand behind their products and customer service is good, something you won’t get with any of the eBay headlights.
Jahson
MADMAN
Florida, USA
madmanmakes.com
I wanted to give you all an update. I did have to to remove the headlamp, but I was able to fix it. Both headlamps work properly now. It was a huge pain in the ass having to basically repeat the entire installation process, but the end result is great. Fingers crossed these last for many years.
Ford Maverick Form Lighting Headlight Install MavLightsOff
Ford Maverick Form Lighting Headlight Install MavLightsOn
bajesus8
Olathe, KS
2022 Lariat Hybrid Lux
What was the process for fixing the headlamp assembly? I got it installed wednesday night and was gonna set the headlights last night, i was watching a movie to wait for night fall...found a level area 25 ft away from a brick wall...then found out my headlights were too high and the adjustmnet screw wasnt making any difference then remembered this post hoping for a quick fix. Ugh i had to give up and drive home with my headlights in everyone's faces...tried to pass a few cops who followed me but luckily didnt notice/let me go as i tried to keep my headlights away from them best i could.
Ford Maverick Form Lighting Headlight Install edited_7918b0a8-266a-44d6-9992-a6e70db5a80a15563528506938347256
Edit: i found a 2nd adjustment screw that i didnt see in the dark the first time. Its working now and im happy.
Toddman45
St. Louis, MO
If you paid attention to the end of the video you use a Phillips screwdriver to adjust the light output. yours obviously need to be raised.
1929
Lake Michigan
Ford Maverick XLT Hybrid
When you have halogen or sealed-beam headlights that have to be replaced every 5-6 years, it's a necessity to be able to pull them out easily. When you have LED headlights that will likely require no maintenance for the life of the vehicle, not so much.
You are removing working lights now and the benefit is not having to replace sealed beam halogen bulb in 6 years? That is more guaranteed maintenance upfront.
Note - Lifetime LED have only a two year warranty.
Tbone289
I'm not removing any working headlights... I'm not sure what the point is that you're trying to make.
My point was simply that it's more important to design an easily replaceable system when it's a system that has parts that are expected to be replaced more frequently.
Length of warranty doesn't necessarily correlate with how long a part is expected to last.
TNFurb
Kelly
Nashville
Perhaps you missed the part of Jahson’s post where he stated that he tried to adjust his headlights using the adjustment screws but it didn’t seem to work for him.
