- First Name
- Altivo
- Aug 26, 2021
- McHenry County, IL
- Website
- altivo.dreamwidth.org
- 2022 Maverick XL hybrid
- Engine
- 2.5L Hybrid
OK, so my '22 Maverick went to the dealer on Wednesday for an oil change and associated services. I also complained about constant "Deep sleep" warnings that didn't seem to be valid because the truck continues to start immediately without difficulty and runs well.
They did the oil change stuff, and after running some tests decided that the low voltage(?) battery was defective. They replaced that under the warranty, which is fine with me.
Two days later, Fordpass is still nagging me to get the oil changed, even though the change does appear under the service history in the app. What's with that? Did they forget to check a box in some software interface? Is there something mechanical that they failed to do to reset the oil change counter?
I had a similar issue with the recall for the air bags. Fordpass kept reminding me to have the recall done even after it was done. In that case it did eventually quit. This oil change nag doesn't seem inclined to go away.
