Ford fixed hood shake with foam tube
Tailender
Will
Poconos
Found this while washing Mini today. Guess they heard about the hose insert trick and decided to use foam tube. They put a garment tag through each end to keep it in place. Truck built early April. Sorry if this was posted already.
Ford Maverick Ford fixed hood shake with foam tube 20220605_164655
Bob The Builder
Butch
Vermont
Garment tag? :ROFLMAO:
Tailender
Tailender
Will
Poconos
Ok. I didn't think it was that funny, but I thought that's what those little plastic tags were called? They hold the label on a garment so you know the price and size. Or am I missing that you're laughing at Ford for using them?
RR - All the way
GA
Hey, built Ford Tough. They will give the shirt off their back to please.. :D
ITSATRUCK
TIM
CANADA
MAVERICK
It might be stupid but if it works is it still stupid! Hope mine has this I'll look for it next week.
Cigargoyle
Denver NC
2022 Maverick FX4K
Mine is like this, and I got it in early November.
Stimpy433
Chad
Iowa
2022 Mavrick
Mine looks like that and was built 11/20.
jdiaz
STL
24 Tiguan 2000 Boxster 1970 VW Westy
My 2/2022 production has that fix, and the hood has quite a solid thud when it closes. I've noted that the alignment at the left rear of the hood (at the base of the windshield, driver's side) with the fender is terrible tho. The passenger side looks good.
Bj517
Nc
Lariat
Is that why those tags are there? I was gonna cut them off haha
I spotted it when I got mine, but looking at the pictures of some of the people who purported to have had and fixed hood shake even they had the foam inserts already. Notice all of these have the plastic retainer/insert visible
I fixed mine I attachEd garage wall protector . What big a big difference. I would say cut it longer got it in Amazon 4 large piece
I just installed the Aeroskin 2 today, and it caused the hood flutter. Bought 4ft. of 1/2" heater hose for $8 at AutoZone. Split it lengthwise and put it over the rear hood seal.
Almost removed all the flutter at highway speed. Still a little but it's in the middle of the hood, more like flexing. Could have been there before and I didn't notice.
Pop your hood, and look up near the windshield on passenger and drivers side there is a square hole and these fit in perfectly. They pop right in and a few adjustments later problem solved
Gullzway
OK
1968 Ford Mustang Fastback
Mine only had the hood flutter after I added the Aeroskin 2 deflector. The foam was already there, including those tags. I added the hose and adjusted the front bumpers to fix the Hood flutter.
willie
fort worth
lexus... ford f150
All that looks to be is caulk backer rod at any hardware store
