Chops
Lobo
Decided to spice up the factory fender vents. I'm not a huge fan of the Air Designs ones, so I decided to add some mesh to my stock ones.
I removed my Air Design Functional Vents and put the OEM back on. Air Design ones were a bit too big.
I did like the air openings however - and your DIY job looks fantastic!
Question - did you Dremel from the outside or backside of piece?
Ford Maverick Fender Vent Mod: Mesh Installed on OEM Vent IMG_9395
Ford Maverick Fender Vent Mod: Mesh Installed on OEM Vent IMG_9119
Automan21
Mel
‘23 XLT Eco AWD 4K Tow
Decided to spice up the factory fender vents. I'm not a huge fan of the Air Designs ones, so I decided to add some mesh to my stock ones. I'm leaving this for anyone who wants to do the same. The only costs were $10 for the epoxy and $30 for the mesh, and that gave plenty extra. The only tools required are a dremel with a cutting wheel and sanding attachment.
BEFORE:
Using a dremel to cut out the middle
Using JB Weld plastic epoxy to secure the mesh
Compared to the original
AFTER:
Awesome work! That’s exactly what I wanted to do!! Which side did you dremel the cover from, inside or out?
Cancunbadlands
Cancun
Cancun
Should added some LED lights while you were there, looking good tho
2023AWD
2023 Maverick
Nice.
I would like to add some turn signal or flood lights there.
Th3118
Mesa, Az
2025 Maverick
I sprayed gloss black inside the hole before i installed mine.
bronxbill
2025 XLT Ecoboost
That came out nice! 👍🏼
I've always been a big fan of mesh grills when done right. Yours came out very well. It looks factory like it should have come with the Lobo package.
I took the easy route and just dropped in some Tufskinz 🤷🏼‍♂️
I did exactly the same thing
LSchicago
Lloyd
IL
Nice little mod. Looks great.
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
I cut from the back side and then sanded the sides to be flush. You could cut from the side but the tabs will get in the way.
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
I thought about it, but wasn't really sure how to adhere a small led strip to the back of the mesh.
Maverick_Dad
Maverick_Dad
Austin
St. Louis
2023 Maverick XLT
I was going to get the Air Designs ones but wasn't sure I'd like how much larger they are. I figured I'd try this first, and it's a lot cheaper. I cut from the back and then sanded the edges down flush on the sides. That was the easiest way. Cutting from the sides would probably leave a nicer finish but the tabs will get in the way while cutting
MaverickNoticer
Smyrna, DE
Maverick '24 XLT
BEFORE:
AFTER:
My brain for some reason thought you had customized with some Fender swag when I read the title
Ford Maverick Fender Vent Mod: Mesh Installed on OEM Vent 1764081779436-lt
Brent@ANParts
Diamond Sponsor
Brent
Phoenix
www.autonationparts.com
Ford Bronco
Nicely done! Definitely gives the truck a more premium look. It's the little things that matter.
Cancunbadlands
Cancun
Cancun
