bgn
WA
How the heck do I get this zip tie off so I can take off the cover?
Don't think I can cut it. And started using the Dremel, but ended up not going through with it because it seemed like a bad idea in case I slip and cut all those wires...
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY PXL_20241024_034317890
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY PXL_20241024_034312366
A.Bursell
Stanwood, WA
You can just cut it with sharp side cutters - it's deceptive it looks very tight and impossible. Once you cut it you will see how it comes out and a new ones goes in.
bgn
WA
Thanks. Cut it without damage (I think) to the harness with those...now I can't get the black cap off. Any tips there?
A.Bursell
Stanwood, WA
IIRC, there is like a tab on the curved end that will let you pop it up and then unclip it from the other side. I'll have to go back and look at my pics if that doesn't sound right.
bgn
WA
You're 100% right. Had to put more force on it than I was before...
AlpineKid74
Graham
Gaylord, MI
2025 Maverick XLT
Yea i might if this thing goes big. But for now i think i have enough. Im not selling a lot .
@Vtec87pr1, I am look @ doing this maybe next March. Truck has to get here first & then warm weather.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
2022 XL Ford Maverick
I got some great news for the ppl that want to do this by yourself with your own diode dynamics fogs lights . I will posting soon a diy with video on how to do it . Using the diode dynamics fogs lights harness. Heres a raw picture of the convertion.
The before and after . Way less wires and more cleaner build and easy to Install. Stay put im busy with 3 im doing at the momment but soon I will try to make it simple for you guys and girls.
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20241111_111448
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 20241111_185543
Dad
Look forward to it.
A.Bursell
Stanwood, WA
Amazon pin kit
Do you think these pins will work in the BCM connector?
This looks like it might be the correct pin to me:
Ford Maverick F-150 Fog Lamp Switch and Wire Harness Installed in Maverick - DIY 1731956965370-c
But I also posted the exact pin to order I think earlier in this thread. Probably end up costing around the same and you would have the exact one for sure.
801Maverick801
Utah
Subaru Forester
Why not buy the 2 pins from ford they even come with the shrink tubing.
Well I'm looking at a lot of mods that involve getting into PCM, BCM and BJB and was hoping I can just buy a pin kit and have everything on hand so I don't need to keep ordering pins from Ford. I've also got plenty of heat shrink and crimping tools so ordering them from Ford doesn't do me much benefit.
Vtec87pr1
Vtec87pr1
Antonio
Virginia
youtube.com
Got you i got some pins if you need them for sale just let me know.
