- First Name
- Cal
- Oct 13, 2021
- Ohio...but I'd rather be in Boone.
- 2025 Hybrid AWD Lariat
- Engine
- 2.5L Hybrid
To be clear you understand that the term “eCVT” is all encompassing of both electric motors and planetary gearset that encompass the hybrid side of the powertrain - sans the HV battery.If you believe the hybrid has fewer parts than EB there is no sense going on with this discussion.
I disagree with much of your reply but if you can access clean data that verifies your stance, I'll change my opinion. However, I'm pretty sure it doesn't even exist, rendering your opinion just that, with the exception of moving parts in an eCVT. but even there I suspect more lines of code.
Compared to the 8F35 the HF55 (eCVT) has roughly 50% less moving parts.
So you are now arguing that a 2.5L Atkinson cycle naturally aspirated engine (which does not add complexity to the engine) is more complex than a forced induction engine - which is hilariously laughable.
You can subjectively argue the EB drivetrain is “better” or more reliable but it no objective terms can you claim it has less moving parts or less complex than the hybrid drivetrain.
We can certainly agree on one thing, and that is no need to continue the conversation when you are so poorly informed.
