- First Name
- John
- Mar 5, 2023
- Kitchener, Ontario, Canada
- 2013 Fusion, 2023 Maverick on order
- Engine
- 2.5L Hybrid
- Banned
- #46
That has definitely not been my experience. Maybe you have a large number of people in your area who do not use the correct oils, or do not change it until the engine falls over. The "huge number of Eco boost cylinder heads" in the first generation (2013-2015) 2.0 engines were due to a gasket leak that was corrected by a small head redesign to eliminate one water jacket hole. Similarly, the 1.6L engines had faulty gaskets causing engine failure early on. The current 1.3, 1.5, 2.0 engines do not have these issues to my knowledge. The 2.7 and 3.5 engines in F150s may, but they are not GDI designs and I don't work on those. One of my vehicles has the early 2.0 head, so I watch for the gasket failure signs. I've never seen a badly carboned up valve on an ecoboost with less than 300k kms. that did not also have an ignored misfire.This is bad information. I was with Ford/Lincoln from 2011 to 2019 and I can tell you with great confidence that we replaced a huge number of Eco boost cylinder heads and even engines due to excess carbon build up. And many at mileage that was shockingly low.
