Easy to handle hard truck bed cover suggestions
ng1021
Nancy
MS
GMC 2500
I’ve read many posts about bed covers. As a 63 year old single female, I’d like suggestions on hard covers I can open and close myself. I’m looking at a RealTruck BAK Revolver X4 for my ‘25 hybrid. If this was for your single mother (or daughter), what would you recommend?
Mudduck
JD
Utah
I looked at that one as well, but settled on the Rough Country trifold. Just had shoulder surgery, and I can open and close it with one hand. Also, the 3rd panel sits straight up and gives access to the entire bed.
https://a.co/d/03s7hHNM
jpj
Pennsylvania
2025 Maverick Tremor Space White Metallic
I opted for the Hard Rolling Truck Bed Cover by RealTruck Advantage® from Ford accessories. It's easy to open and roll up. It was delivered for pickup at the local Ford dealer. The dealer can install. I especially like it for being able to set groceries and other items on top; up to 300 lbs, while putting items away.
Hot Runr Guy
West Chicago, IL
What do you think your usage will be like? I also have a tri-fold, and rarely open more than the first section, which is easy to flip over. Do you think you'll be needing full access on a regular basis, or just once in a while?
HRG
ng1021
Nancy
MS
GMC 2500
HRG
The first fold of a tri-fold is easy, it’s the other 2 that are too heavy for me! 😬 And I would only need full access once in a while.
zorki1c
Wayne
Boise Idaho
1994 Maverick Lariat
HRG
I’m like you. Seldom open more than the first panel unless I need to haul something like an appliance or furniture
Wahjahbvious
Don't Worry About It
Erf
'26 Hybrid Lariat in a color that seems to anger the dumbest people you know
I've learned one thing in all my reading on this subject: everybody loves what they bought.
So I kinda suspect they're mostly all fine.
Assume some degree of get-what-you-pay-for-edness in the build materials, set a budget and buy the name you recognize.
Dave O
New Smyrna Beach Florida
I have the Retrax XP Pro Retractable Hard Cover I purchased from RealTruck I absolutely love it
Ford Maverick Easy to handle hard truck bed cover suggestions IMG_4700
Johnkn
MD
The Retrax Pro is among the best, I had them on both my Raptor trucks and currently on my TRX. The downside for the OP might be the $2k cost. My guess that the slight loss of front bed space with the canister may not be an issue for her.
EffNo50
Central California
Depends on if you want the added security (and expense) of a hard cover. The soft covers are the lightest and easiest to roll. They are also easily "opened" with a sharp knife. I used one for a while and found pulling it snug engaging the velcro on both sides a bit annoying but necessary to reduce the freeway flapping.
I now have the Leer HF650M hard folding cover and really like it (5 hard sections, 4 folds). I imagine a rolling one would be slightly easier to open and close, whether it rolls up on top, or into the canister underneath. My requirements were not blocking the 3rd brake light when open and not leaving a good portion of the bed covered when the cover was open as some don't fold up the forward most section (3 sections, 2 folds). It is really handy to have a surface to set things on with the hard covers to free your hands to unlock the vehicle or open the tailgate.
MavStangVa
Here, There, and Everywhere
2024 LARIAT AWD
I have the same cover and I am mostly pleased with it. I will work on water infiltration this spring and I am trying some differnt clamps to allow full use of the rails in the bed for tie downs. I ordered directly from Rough Country so Amazon didn't get a cut.
chrisofpa
Hawley, Pennsylvania
2025 Ford Maverick Tremor
I like my Diamondback but they're not cheap.
chrisR
chris
Burford Ontario
will be a 2025 maverick
I have the hard roll up through Ford .I know not cheap .But ive been quite happy with it.
Ford Maverick Easy to handle hard truck bed cover suggestions IMG_0180
Gray Goose
RG
Wissota
A consideration: if you live or travel to an area that gets ice or snow, a tri-fold has fewer seams susceptible to an ice bind.
Ben6berry
Benjamin
Yakima, WA
2025 Ford Maverick Tremor, 2001 F150 Lariat, 2020 GMC Acadia, 2015 Caddy SRX
I opted for the hard retractable tonneau cover. Easy to use. Looks great. Fairly easy to install.
