"Dumb" key to leave in ignition
Hot Runr Guy
West Chicago, IL
OK, I'm probably too cheap to order a Lariat-level just to get push to start, and I don't mind having the fob in my pocket, but is it feasible/possible to have a key blank cut and leave it in the ignition switch? If the fob controls all the electronics, and all the key does is allow the tumbler to turn, it might be a workable compromise.
HRG
jewc75
You probably could but why would you? Key fobs can be hacked now and it would make it easier for a thief to steal.
Eagle11
Valley of the Sun
Well, grasshopper the keyfob in the lower level only locks and unlocks the door, it doesn't have any control if the vehicle can start or not.
Hot Runr Guy
West Chicago, IL
Thanks. I wasn't sure if an XL/XLT would be able to start if the fob wasn't present.
HRG
commadorebob
Engine immobilizers are standard on all Mavericks, XL on up. But don't do that. Most crimes are crimes of opportunity. Providing token resistance (such as not leaving a key in the ignition) helps.
paneubert
Seattle
* Your insurance agent has entered the chat *
rlhdweman
Random Lake Wisconsin
Even if you could find a sidecut key that didn't have the remote electronics, you would still have to turn it when you enter the vehicle with your remote. :unsure:
Eagle11
Valley of the Sun
To make sure we are all on the same page Unless your Maverick has push start, there are no electronics in the Key fob.
It should still have a PATS RFID authentication.
So the real question for OPs idea of keeping a fully functional key fob in their pocket is what range does the PATS transceiver in the steering column have and is it sufficient to activate/read a key in the pocket?
Hot Runr Guy
West Chicago, IL
So, I took the battery out of my 2nd fob, and the vehicle would still start with a (fairly) dumb key. Not sure if the vehicle is still sensing something within the (un-powered) fob? I haven't yet removed the roll pin to release the key itself from the fob, may try that some other time.
HRG
paneubert
Seattle
HRG
I think the chip literally INSIDE the metal portion of the key does not require it's own power source within the key or fob. It is most likely powered by the ignition somehow. How do I know? I have bought "dumb" key blanks that do not have a battery at all. The battery in the fob is for the fob buttons to lock and unlock, not to power the anti-theft chip in the key.
Especially if @Darnon 's mention of RFID is accurate. RFID transmitters do not have their own power source. Receiver/reader provides the power via induction to the antenna in the un-powered chip/card/user held item, etc.....
jsus
2022 Ford Escape Hybrid AWD
HRG
The key's battery is for the remote functionality (lock/unlock/alarm/remote start if applicable). SecuriLock, Ford's PATS (Passive Anti-Theft System) system, relies on an RFID chip inside the plastic housing of the key. That RFID chip does not require a battery. Even if the key battery dies, the vehicle can still be started.
Back before they integrated the remote fob into the key, they had a black plastic head on the key that included just this basic RFID functionality, and no battery. Would've looked similar to this:
Ford Maverick "Dumb" key to leave in ignition 1684512597391
All of this remains true on a Lariat with push-button start - there is a backup location to place the key to start the vehicle in case of a dead fob battery. Of course, that fob usually uses the battery to enable you to keep the fob in a pocket/purse/wherever, but the backup relies on similar tech that does not require battery power in the key.
Eagle11
Valley of the Sun
HRG
As I wrote, in the XL and XLT without push start the Key Fob hasn't helped to start it. Why do you want to leave a dummy key in the ignition?
Hot Runr Guy
West Chicago, IL
In my pea-brain, being able to leave the fob in my pocket, and just turn a key left in the steering column is as close to a push to start button as I can get, without paying for a Lariat.
HRG
Ranch
Sacramento CA
2023 Marverick FX4 4K
HRG
I think I understand your goal now.
You want to know if you could have a "plain" no button key that you could leave in the lock cylinder/switch and do a "twist to start" instead of a "push to start" with the Fob in your pocket.
