Does the horn beep when you lock/unlock ?
NJ Pinelands
New Jersey
Chevrolet
Just wondering if the horn beeps when you lock or unlock the Maverick. I hate hearing vehicles do that and I sometimes don’t get home from work until very late and I am sure my neighbors won’t be dancing a jig having to hear that.
Should be only when you press the lock button twice. Or, with intelligent access key, if you close the door with the vehicle running and key outside of the cabin.
jewc75
It can be disabled in the truck settings.
NJ Pinelands
New Jersey
Chevrolet
I have the hybrid XL so I think I get a regular key.
jewc75
Is that easy to do ?
Yes. controls are on the steering wheel. I had to turn mine on, it was off from the factory or dealership. The horn also lets you know if you didn't shut a door or hood when you lock the doors. If a passenger gets out and doesn't close the door all the way when you lock it, it will double honk letting you know something isnt closed and it will not lock. If the horn is off you will never know that it didn't lock.
Stock411
HI
2022 Ford Maverick XLT Hybrid
Click keyfob once, it illuminates letting you know it’s locked.
click key fob twice, it does the same but sounds the horn for a second.
KenJ45
2022 Ford Maverick XLT 2.0L Ecoboost
Yep, it's useful, it lets you know if a door is not shut properly by doing a double beep. If you don't want to hear it, just press the lock button once. It only beeps on a double press.
Marco Goose
Marco
East Rutherford New Jersey
2024 Mavick XL
No when unlocking. Mine beeps when the lock button is pressed twice.
Darthie
Frank
Hmm...actually on the wheel. I'll have to look. I would like mine to beep when the lock button on the handle is touched.
If you have the intelligent access fob. Get out of truck while it's ready get the double honk. If you want to leave truck ready with AC or heat on while outside shut the door and lock with fob (not sure maybe with door handle also). Then you can walk away and truck will stay on until you return. (If going to be gone over 30 minutes you may need to turn off the 30 minute max idle timer if it's on).
He meant controls for the Truck settings menu - in other words not a setting in the infotainment center screen.
So not an actual button.
It's this Feedback option for the key double-lock press honk.
It's this Mislock option for the chirp on key single-lock press if a door/hood/tailgate is open. Might want to know about that one.
Ford Maverick Does the horn beep when you lock/unlock ? IMG_20241120_092308226_HDR
No sound for lock button.
Well - unless you have key in ignition and hit Lock All button.
I think the same thing if you have keyless entry and fob in car.
Prevents accidental all-door lock when key's aren't with you.
Does NOT prevent pressing driver door lever lock with keys in cabin though.
Darthie
Frank
Ahh...thank you kindly.
