Does full size spare have TPMS?
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
Well, if i knew the truck came with a spare thin tire, i would not have ordered the full size spare, $115 down the drain.
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
Ok, ca
based on that sticker the “full size” spare is 1.3” shorter than the on the ground size, or 4.6%.
not sure how fords AWD system is but I know on a lot of AWD cars thats a big no no.
Oh boy tire size brain exercise!
Does the smaller full size spare at 39 lbs (compared to the not full size spare inflated to 60lbs) have the same rolling radius as the 4 "standard" size tires at 35 lbs? Also does the small size spare have 3/32" tread and the full size tire have 6/32" and the standard tire have 9/32"? Also notice the spare has 100 weight range instead of 102 but since they all are H speed rated you can drive FAST to the tire shop!
villageidiot
Southern California
many many in the past, none currently
Ok, ca
im gonna hazard a guess that I don’t care how much inflated it is, it won’t grow 1.3” in height.
the last time I had to use a spare was on my jeep, and ran over a monster chunk of steel. Tire got replaced the next day and the spare went back to the spares spot.
5 tire rotations are a pain in the ass.
I just prefer to be able to get home safely/finish a trip if I need.
I’ll go as far as seeing if a TRULY full size spare can fit up under the bed.
vezpa
EMG
IL/IN border
Too many to list.
V2WIN
Ivan
2022 Maverick XLT Hybrid
Does any maverick trim have TPMS? A base subaru forester...more roomy...no pickup bed....is better equipped for $25k and 33mph highway...just comparing and saw the base model includes TPMS which I check often.
Thanks.
I owned a 2010 Forester bought new & it started to use oil about 75k miles. Blown head gasket. That engine had a timing belt so belt, tensioner, pulleys, water pump both head gaskets & $ 3500 later I had my fill of Subaru. Never again will I buy a boxer even in a Porcshe.
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
What oil brand were you using ?
Fred
IL
Ford Escape
All new cars, trucks, and SUVs have TPMS, ever since the TREAD Act was passed in 2008.But kudos to Subaru for doing the same thing everyone else is doing... :sneaky:
I wasn’t clear....many cars have the TPMS as an idiot light, but in the subaru it has a screen with the individual pressures listed...not simply a ”tire!“ icon.....has anyone seen if the maverick has the individual pressures in a menu or screen? It‘s nice to see if one tire is low and which one rather than manually checking the pressure to find the offending tire.
Thanks...
DryHeat
DryHeat
Arizona
Jeep Patriot
Manual, page 344:
Ford Maverick Does full size spare have TPMS? 1633484003619
V2WIN
Ivan
Mobil 1. That said Boxer engines have a tendency of failed head gaskets. The oil can't completely drain & just lays on the gasket. BMW / Honda motorcycles & Porcshe boxers ALL have this problem.
Fx4hOok
Kevin
MA
Maverick 2.0 FX4
I had rear main seal leak on my camry with just 30k using mobil 1, never again, will be going Castrol edge with the Maverick and been using Pennzoil on the camry ever since that happened.
Jukebox Nero
Carl
Draper, UT
2021 Ford Maverick Lariat Alto Blue FX4 4k 2.0 EB
On a side note, the full sized spare is an Atlas Priva C/S at 215/60/r17. Not sure how that is considered full sized, but mine has been replaced with a true full sized spare now.
vezpa
EMG
IL/IN border
Too many to list.
How can you have an AWD system with a spare that is over an inch shorter than the other 4. Using such a different tire size would be the biggest no-no with an AWD. Can someone confirm this is a FWD and not AWD?
Ford Maverick Does full size spare have TPMS? tirelabel-
Krrr
SW PA
2022 Maverick Hybrid
My question to all is:
Will a full size spare fit into the the present XLT spare tire slot, under said vehicle?
