DIY bed divider
felsf50
Scott
NEPA
Stole this idea from another member. A 2x6 cut to 54.25 inches. Course sanded and sprayed with 3 coats of Rustoleum bed liner. Nice snug fit.
Ford Maverick DIY bed divider PXL_20211218_191842805~2
pnorwood54
paul
ALTO BLUE XTL AWD-4K-FX4-360
wonder if its <1/4 in longer with no spray in liner
DCP
Tennessee
2014 Flex, 2018 Escape, 2023 Maverick XLT Hybrid
First, congrats on having a Maverick in which you can place a DIY bed divider! That's a tremendous accomplishment.
Add a couple of drawer handles on top or cut two hand openings for convenience.
jwilson
NJ
PENDING MAV XLT/Hybrid
I'm thinking about doing the 2x6 and wrapping it in trunk liner carpet (black). Make for a more snug fit in the slots and less scratching, easier to handle. But hey, I've got a solid six months to figure that out!
Vickyfortin1985
Vicky
F150
I love your idea! I've got some liner lying around, I'm gonna try it when I have my truck and a tonneau cover!
Sylvester
Ford
Looks great! One small addition to this: If you want to do a third bed divider for the horizontal slot in the front of the bed, the measurement is slightly different, you have to go exactly 55". Just to let everyone know who wants to use all the areas of the flex bed.
KRae
Kareena
Denver, CO
Suzuki SX4
Mailman13
Georgia
Maverick Lariat Cactus Gray
I just got my Lariat with sprayed in bed liner, so your idea with the carpet is perfect!
thank you
YOBY
Yoby
Pa
2016 RAV 4 / 2022 Maverick Lariat
I have a spray in liner and ran into one little problem. I used a 2x8 and have a Lomax cover. To get the board out, I need to get into the bed to lift the board and maneuver it from under the Lomax rails. If I don't and lift from one side and go to the other side the board will drop back down. I know I could block one side and move back and forth from one side to the other, but that's a pain in the butt to remove one board. The only other way is with two people, one on each side. After all that work, I still need to work the board from under the rails.
Lesson Learned: Use a 2x4 if you have a cover.
Mailman13
Georgia
Ford Maverick DIY bed divider IMG_1234[2372]
On my Lariat OEM sprayed in bedliner, I used two 2X6's instead of one 2X12 because of the manuvering issue. I'm 6'2" and 240 pounds. At 60 years old, I don't hop up and down like in my younger years. The boards do kind of still hit the bed rails if I move them while standing outside the bed.
I used thin, flat rubber strips on just the ends of the boards, (stapled deep) since the rest of the board doesn't touch the truck bed really. I still may wrap them in carpet like the OP said that he was doing.
Oh and no noise either.
Sorry for the quick, sloppy "Paint" job. my garage is a mess so...
Ford Maverick DIY bed divider 67563382128__61427B8D-4447-4F49-8264-6C9C242D7E1A.JPG
Lone Star Proud
William
Central Texas
Ford Maverick XLT
I went with a 2x8 for a taller divider. I cut a pipe insulation tube to use on both ends to cushion the board and prevent damage to the paint.
