Barracuda340
Abilene Tx
Seriously, this is the innovation? Just get this instead for 16$ if you're the one in a million that has a rack that blocks a 2x6 from being pulled out.
I have one of these nets. Its works great for when I go food shopping, however it doesnt fit everything, and some larger stuff ends up sliding towards the front. I have a tri fold bed cover, however I dont feel like opening it to retrieve stuff that's rolled to the front or to climb inside to get it. This is why I am welding up a folding divider out of square thin wall steel tubing. I'm back on shift at work for the next 8 days, but the next time I am off, I will be starting on this project.
JBryant
Jesse
Bowie, TX
More flexible handling? ... space saving storage? ... lighter weight? ... if you are happy with yours, more power to you.
Looks great and great idea. Obviously, everyone likes theirs better, but so be it. You have great storage flexibility this way.
rclee
Rob
Dayton Ohio
I cut mine to the correct length. It drops in ok but getting it out is kind of a pain with the SIBL. I also added cheapo door stoppers so I could hang the handles of the plastic grocery bags on them. The stoppers give you a place to lift up on the board (divider)
Ford Maverick DIY bed divider with lockable hinges IMG_0806
MAVRICK
Any
2024 XL
Lighter weight??
Depending on the type of material used (wood or other than wood) which may compensate for the added weight of the hinges while adding flexibility ... lighter weight does require some trade offs.
shadowthrone
us
23 Maverick
This is actually the exact idea I was looking for! The MX4 cover rails make it basically impossible to slide in the divider, and this is an easy solution for getting that board in place.
Suzukiridr14
Frank
Sarasota Florida
the description says 'for easy removal' but ... it's just as easy to lift and remove an uncut piece, and save $12, imo.
The reason for the hinge, is because he has a rack on his truck that prevents the board from being removed straight up.
  • Like
Reactions: Bry
Hardening2753
Ford Maverick Hybrid
Since I installed my roof rack on the side rails, I can't slide up the divider. DIY bed divider with lockable hinges. I used a lighter weight 1x8 pine wood x2 cut to 54 1/4, lightly stained black. Cut in half and install lockable hinges for easy removal. Cheap hinge a pair for $12
Amazon link for the 180 degrees
https://www.amazon.com/Skelang-0°-90°-180°-Foldable-Extension-Workbench/dp/B0BN7YJT1V/ref=sr_1_1?crid=11FSI5AH5V52Z&keywords=Skelang+2+Pcs+Folding+Brakcet+0°-90°-180°&qid=1687957527&sprefix=skelang+2+pcs+folding+brakcet+0+-90+-180+,aps,111&sr=8-1
How much weight can your rack hold?
Hardening2753
Ferdinand
The lockable hinges are a great idea. I followed your advice and bought them at Amazon.
The hinges makes it versatile and easy to install !!
Here is the result:
Ford Maverick DIY bed divider with lockable hinges IMG_0341
Ford Maverick DIY bed divider with lockable hinges IMG_0345
Ford Maverick DIY bed divider with lockable hinges IMG_0347
Bry
Bry
Bryan
Mission Viejo, CA
Maverick XLT Hybird
Here is the result:
So awesome dude, easy and cheap DIY!!
