- First Name
- John
- Oct 31, 2024
- Pacific Northwest
- 24 Maverick XLT CG, 92 Ranger
- Engine
- 2.5L Hybrid
Good point on the jump points - it's not like using a cigarette lighter socket. I'm not looking to run power equipment on the job site - just intrigued at being able to use the Mav for spot emergencies as we have occasional power outages - usually in the middle of the night when I don't want to have to go and dig out the generator.pros and cons to both.
since a jump start would definitely be a ton of current coming down the factory cabling between the jump point and the hybrid 12V battery, I'm sure it's overengineered for the load. but I'm also confident that's a long enough run that it would be more efficient to connect directly to the positive terminal on the 12V.
the other issue is if something were to fail with the inverter having a high current device in the cabin is less desirable than having it in the engine bay. if it melts, it's stinky, if it's on fire it could be much more serious.
