sme1974
Conyers, GA
2025 Maverick Lariat Hybrid
^ THIS ^. I have a 2025. One of my main and only frustrations with my truck is the inability to retain the "My View" settings. I have certain checkboxes checked on the menu, and it just will not retain the settings and display correctly.
I want to check tire pressure every time before I get too far from the house. And I can't get rid of the "Fuel Economy" screen which shows the cumulative mileage which is not relevant. I assure you that "Tire Pressure" is checked on the "My View" config menu and "Fuel Economy" is not.
So I have learned to do this almost every time I begin a trip: I toggle some buttons on the RH side of the steering wheel:
1) Press the "hamburger" button (3 horiz lines) to go to the Menu
2) On the Menu press "OK" to select "My View" on the top line
3) On the “My View” screen it will go to "Configure My View” on the top line. Toggle up once to “Tire Pressure” which is at the bottom of that list
4) Press "OK" to select "Tire Pressure" while still on the “My View” screen
That’s it. 4 clicks. It will go to Tire Pressure. For some reason it deletes the "Fuel Economy" screen from the rotation and adds "Tire Pressure", and keeps the other screens in the rotation as is, which are the ones I want.
But the next time I start the vehicle it will revert back to the previous rotation with Fuel Economy in and Tire Pressure out. It makes me want to smash something, but I somehow control myself.
It's become so routine that it takes me just seconds and only 4 clicks. I have a base XLT and I have never had any issue with being unable to view the Tire Pressure, so all of this talk about OTA updates and other people's issues is crazy talk to me.
But I wish Ford would figure out an OTA update to fix this glitch and retain the settings as intended. I can't be the only one to complain about this. It's ridiculous!
I have the same experience and it's frustrating that it won't save even for that drive session, can't understand why that is! Yes, Ford fix this!!!
Did you get that to display on your screen by just going thru the settings on the steering wheel? I have a 2023 and would like to see it also . Thanks
Lariat vs non-Lariat display difference.
If you mean the TPMS readings - under Info.
Mdmac
Kansas
2023 Maverick XLT
Thank you, is there a way set it so I can see it all the time? Or do you have to go through settings every time I want to see it?
Every time.
Since it's my only setting I look at basically - I just get to the Settings view Ok button, Menu button, Ok, Ok - see where I'm at before driving off. Then Menu button to drop back to Views.
Since it's more curiosity info while driving I rarely look at it.
Not like I'm going to stop to let 1 PSI out to have them matching.
I know I'll be alerted in Ford app if something bad happened overnight.
lavaspill
Same experience with the 26. Reverts back no matter how many or few items you select in My View.
KO Stradivarius
The Disputed Lands
'25 XLT
We are being held back by technology.
Ford is pulling defeat from the jaws of victory!
Assuming this issue is only with the 2025’s and newer, it has been existing for about 2 years and still isn’t fixed.
So Ford either doesn’t know there’s a problem, or they know about it and haven’t got around to fixing it. Or even worse, they are incapable of fixing it.
All of these possible scenarios are bad!
Ranko Kohime
Ranko
2025 Maverick XLT
When you open the door, you mean when you open the door while running the display disappears? And you have to open the menu to bring it back?
I think this happens to me as well but it never registered.
Correct. I don't turn off when refueling, for example, which I will sometimes do 5x daily. Or stopping at rest areas. Every time I open the door, whether the MyView or the standard right hand side display disappears, along with the speedometer itself.
Ranko Kohime
Ranko
2025 Maverick XLT
I don't place sufficient trust in any major company (and especially not a hardware company) to make good software.
My Stallman beard just keeps getting longer on this issue.
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
I think you're onto something I had and overnight update done and I can only see My tire pressures when I'm not moving!!
Update on the way home from work tonight I clicked on My View and Tire Pressure and was able to see the tire pressures while driving!!
mauverick
jp
XLT Luxury Package hybrid AWD 4K towing AWD
I'm gonna just tap the sign again...
(And for those who might not be fully technically literate, the availability of source code, and the ability to load custom code on the various parts of the truck, would allow not only for restoring something removed in an update, but also custom displays that the manufacturer never intended. Sure, I can get the HVB temperature via my ScanGauge, but why not have it, and all the other temperatures to hand on the main HUD?)
As a recovering software engineer, I have to warn you to be careful what you wish for. Remember the golden rule, every new feature adds ten new bugs 😜
GmanGM
Garry
Baltimore
Dakota
Guess it "their view" not 'My View"
Darryl
Darryl
Tallahassee Florida
2025 Maverick XLT HYBRID
I believe it's still visible but through a different menu. I think you can choose to display it on your view setting
BLUEOVALRACER
Ravenna,Ohio
See post 41 I was able to open the Tire Pressure under My View and now I can see My tire pressures while I'm driving!!
