Pointyears
South Central PA
Oh - there's a known reason - pre-25MY.
Not a problem on those.
I'm still stumped on the 25/26 though - is there a 2nd screen with the info that will display while driving, and another screen that won't - or totally the difference with a software upgrade that happened for some?
My hybrid LARIAT 25 works identical to post 11.
So those of you that can see it - is there another screen that won't show it, and that is the reason for the complaints by those that it recently went missing?
Now we just need those posting it changed and it's gone - to follow those instructions and see if it's actually there in a different place.
Or indeed - were are talking pre & post OTA software update.
BLUEOVALRACER
Ravenna,Ohio
2025 Maverick XLT AWD
I believe that ability was disabled after an update. But if it makes you feel better, the light will still come on if the pressure drops while you're driving. I know because I picked up a screw. And the light came on after I'd been driving about 5 minutes.
I think you're onto something I had and overnight update done and I can only see My tire pressures when I'm not moving!!
Kenv24
Ken
2024 XLT
Considering posters have commented it changed after an OTA update - probably useful to share if you have updates enabled, and when/what was the last one.
I might be wrong, but I thought it only disappeared on the Ford Pass app...not in the actual truck display.....No??
Marty
2026 Ford Maverick Tremor
^ THIS ^. I have a 2025. One of my main and only frustrations with my truck is the inability to retain the "My View" settings.
I want to check tire pressure every time before I get too far from the house. And I can't get rid of the "Fuel Economy" screen which shows the cumulative mileage which is not relevant. I assure you that "Tire Pressure" is checked on the "My View" config menu and "Fuel Economy" is not.
My view holds my settings including TP but now you’ve got me wondering if I can ditch fuel economy.
I’ll look into that,
2026 Tremor if that’s a factor.
REMUB40
Fredericksburg, VA
2018 Honda CRV
You should be able to pick and chose what you want to display. There are more options than allowable displays. I have a 23.
KO Stradivarius
The Disputed Lands
'25 XLT
Yes, I agree that you should be able to choose which screens, but I absolutely cannot. I think it may be an issue with '25 and beyond. But like I described in Post #11, Tire Pressure disappears and won't remain in the display rotation (although the checkbox is chosen on the config menu screen), and Fuel Economy keeps returning (although this checkbox is not chosen).
But every time I manually select Tire Pressure, it will display, and Fuel Economy will disappear (which matches my checkboxes), I assume because the max number of screens in rotation has been reached.
It is a 1 for 1 replacement. Not an issue with too many being selected. Actually I don't think you can choose too many, it won't let you.
All of the other screens that I chose have no issues (Trip 1/Trip 2/This Trip/Hybrid EV Coach) - they always appear. It is only TP and FE that cannot cooperate. It is clearly a bug.
There is no possible explanation for why it will not display the chosen configuration. Why can't these idiot software engineers fix this? The '25's have been out since, like late 2024, so it has been almost 2 years!
That's fuel level.
Bdesign
Santa cruz, CA
2025 Lobo MPC EB
You can only select a given number of items to display. if you have too many checked, it will not display some because there are too many selected. You need to check only 5 to be sure the 5 you checked are displayed. Any checked beyond the first 5 will not be displayed.
Ranko Kohime
Ranko
2025 Maverick XLT
I'm gonna just tap the sign again...
NO SOURCE CODE?
YOU DON'T OWN IT.
(And for those who might not be fully technically literate, the availability of source code, and the ability to load custom code on the various parts of the truck, would allow not only for restoring something removed in an update, but also custom displays that the manufacturer never intended. Sure, I can get the HVB temperature via my ScanGauge, but why not have it, and all the other temperatures to hand on the main HUD?)
KO Stradivarius
The Disputed Lands
'25 XLT
Hello, it's not clear if you are replying directly to me, but I do agree with you.
However, I will repeat what I wrote earlier:
"It is a 1 for 1 replacement. Not an issue with too many being selected." ​
I don't have too many selected, I have 5 selected. And I listed the other 4 that are selected in addition to Tire Pressure (TP).
It is a clear case where I have only 5 selected, and although TP is checked, it will only display when I reconfigure it during that trip. It IS NOT displayed after I restart.*
Fuel Economy (FE) always reverts back to being displayed after restart* even though it's not checked.
*NOTE: I have noticed a few times that if I restart after a short time, like 5-10 mins, it will retain the correct settings for the next trip. But after a longer period of sitting, it will not.
Ranko Kohime
Ranko
2025 Maverick XLT
I will state the issue I have, with my non-updateable* '25, and see if that contrasts to the behavior you see. I setup My View to include tire pressures. On restart, sometimes it will return to My View, as you mention, but often does not, returning to the regular, fixed options view (with Trip 1,2, Current Trip, Fuel Economy and EV Coach in that order) that disappears whenever the door is opened while the truck is on. I have to go into the menu and specifically select My View, but I do NOT have to re-add tire pressures to My View, unless the 12V battery is disconnected for a time.
Does that jive with your experience, or differ?
* I pulled fuse 11
KO Stradivarius
The Disputed Lands
'25 XLT
* I pulled fuse 11
Yes, that’s pretty much the same as me. You called those 5 the “regular, fixed options view”, which are the exact same 5 that mine always reverts back to, regardless that FE is not checked on the selection menu and TP is. And the 5 checkbox settings never change, and I have never disconnected my battery to see what happens.
When you open the door, you mean when you open the door while running the display disappears? And you have to open the menu to bring it back?
I think this happens to me as well but it never registered.
