Diference on hybrid vs tremor struts FYI
Bwicka
Lakeside,ca.
Just thought I’d show pics of a stock hybrid strut and a tremor .
Ford Maverick Diference on hybrid vs tremor struts FYI IMG_2950
Ford Maverick Diference on hybrid vs tremor struts FYI IMG_2949
Ford Maverick Diference on hybrid vs tremor struts FYI IMG_2954
Ford Maverick Diference on hybrid vs tremor struts FYI IMG_2952
Ford Maverick Diference on hybrid vs tremor struts FYI IMG_2953
all appears to be spring thickness ( pre-tension ) for the ride height , overall rate , and obviously different valving to control that rate .
Thought I’d throw it out there for anyone wanting to know.
bolt right in .
Interesting, but what use would there be in having swapping the front? The rear suspension isn't compatible between fwd and AWD models.
fossil
ernie
ohio
bolt right in .
Thanks, anything learned adds to the library. FX4 is a missing bit
Every thing points to Tremor spring rates being lower than FX4 starting with reduced payload.
HTX
Jon
Houston TX
CR-V
Appreciate this post. Curious to see if you notice a difference in ride quality.
Maverickman74
Shane
Maui HI
Factory leveling kit? Probably a big hit in the Carolinas. Plus the improved shocks would make for a better ride if you had rough roads on your travels.
Nw_adventure
Salt Lake city
Also trying to figure out if Tremor shocks would work on our FX4 that has the tow package and HR lift springs ? The ride quality has gotten a little worse since it's been lifted for over a year now. Still decent ride but a little too bouncy I guess.
blackb13
If this softened up the ride but kept the height the same, it could be a godsend for hybrid owners looking for a more compliant ride. Of course they're probably insanely expensive.
Bwicka
Bwicka
Lakeside,ca.
Yeah , I won’t know on ride quality , I went flat out suspension on my tremor , that’s why mine are off the truck and the hybrid one was off a wrecked truck I’m fixing and flipping , just thought I’d compare and post . I had quoted a strut and spring price at ford dealer , believe it was about $130 for a strut and around $50 for the spring , so about 200 each corner and they were about a week out ( Detroit stock).
Gotta remember this IS a cheap truck so parts even at the dealer not that bad.
Bwicka
Bwicka
Lakeside,ca.
Except rims and radiator plastic shell , and headlights .
those 880, 700,1200 respectively priced each!
PacmanROMAD
Steven
Greeley CO
2025 Maverick XL
Thread may be too old, to reply to. Posted this exact question before I found this thread. Just got my 25 XL AWD Hybrid. $500 to level my new truck with factory parts seems a good deal. Has anyone ever actually tried this swap on the front only?
