Transmission coolers- 4k tow vs. Tremor
FischAutoTechGarten
Peter
Looks like 4K has a transmission cooler and FX package does not…..
Yes, that's understood. But what I'm questioning is what I circled... what is the difference in the cooling fans.... I'd say none, but the descriptions are just ever slightly different, which might be a weasly way of saying they are different...
Iakona
Jason
Elgin, North Dakota
2023 Maverick Tremor
I think it does, "3.63 standard/3.81 with 4K Trailer Tow Pkg"
You would indeed be wrong. The Tremor has the 3.81 final drive ratio just like the 4k package trucks. It is a lower tow limit due to suspension tuning as is the case for all off road versions of all pickup trucks.
Boosted
BoostedMaverick
2024 Ford Maverick EcoBoosted Tremor w/Terrain
https://media.ford.com/content/dam/fordmedia/North America/US/product/2023/maverick/pdf/2023-Maverick-Tremor-tech-specs.pdf
Only the 4K tow package gives you the higher final drive ratio. Tremor falls under standard ecoboost final drive ratio since it is rated for max of 2000 lbs towing.
Also the payload capacity is about 300 lbs less, 1200 lbs for a Tremor vs 1500 lbs standard.
Actually the lower 3:81 Final Drive Ratio is on the Tremor (3:81 Final Drive Ratio is lower than 3:61) *see footnote 1.
Ford Maverick Transmission coolers- 4k tow vs. Tremor IMG_5848
