Dashboard noise solution?
Justin says...
Justin
NC
'22 Ranger XLT
Nope I dont think so. Mine makes a pop noise literally all the time. Seems like it's coming from the left -ish side but it's hard to tell.
TopDawg
Randy
Lexington, SC
2012 Ford F250 Lariat 2WD 6.7
I put house screen rubber strip between front pillars and dash wit screwdriver on each end and stopped the noise.
Tony B
Anthony
2 Stillwater Road South Deerfield, Massachusetts
2022 Ford Maverick XL EcoBoost
Good morning, Tony. If you'd like to, go ahead and send us a private message with your VIN and dealer info and I’ll look into this dashboard noise concern. Thanks!
My VIN # is 3FTTW8F9XNRB12828. Sarat Ford 245 Springfield Street Agawam, MA 01001 www.saratford.com. Thank you for your help !
Second try maybe the answer can help others with this question & problem. May I be advised as to receipt of requested information ( VIN # & Dealership ) at some point !
Alharm1
Alan
USA-WV
2024 Maverick Lariat Tremor
Same. Mine is driver’s side near windshield. Sort of a low key knock. Almost sounds like a marble rolling back and forth. Can put my fingers in the defrost vents and it seems to stop.
bgn
WA
Search for windshield alignment pins on here. It's likely what's causing your issues, especially if they get worse with the colder weather.
12beach
Massachusetts
2024 Hybrid XLT
Its probably the windshield pins. My dealer already took my windshield off twice to "readjust" the pins but the noise keeps coming back. I am going to go to a different dealer, because the readjustment does not work for more than a few days.
The dealer told me another Maverick owner had the same issue with brand new truck and it is a factory install problem. Ford needs to recall this. It is unacceptable especially for a brand new truck.
bgn
WA
Mine was built October 2021. Don't count on them issuing a recall. ;)
ejouie
Evan
Newnan, GA
'23 Ford Maverick, Atlas Blue, FWD, EcoBoost, XLT
Windshield alignment pins is one source. Pin removal can solve this issue.
Another is the tweeter speaker grills/covers tapping again the pillars. Felt tape on the speaker cover side of the contact area has been recommended to solve that.
Some also have a noise coming from the base of the windshield dash area. Foam strip/weatherstripping down in-between the windshield and dash seems to work for that one.
Tony B
Anthony
Justin says...
Justin
NC
'22 Ranger XLT
YES. Exact same noise. I describe mine as a plastic-y knock sound.
