CV axle - Sign of leak and likely eventual failure
Zolutar
Sea to Sky, BC, Canada
23 Maverick Lariat Lux Hybrid, 21 Bronco Sport OB+
Mine's an early 23 Hybrid Lariat. The front end shake kinda started over the summer under acceleration but has really intensified under heavy acceleration recently. I came accross these CV threads and decided to take a look. And sure enough, passenger CV axel is leaking.
Appt made. Stay tuned.
Ford Maverick CV axle - Sign of leak and likely eventual failure 1000021335
Fibrepunk
2023 Ford Maverick XLT Hybrid
Hopefully the dealership will have the part and get your situation rectified ASAP.
Zolutar
It took a bit, but both half shafts got replaced under warranty at the dealer and all is good again :)
CSP 25N09 does not apply to Canada as a fact, It applies to the USA only.
Though it helped with diagnosing the problem, but for this dealer, mine is the first they have come across with this issue.
Fibrepunk
2023 XLT Hybrid
- 21,507 miles
- Passenger side showing it leaked a little more comparing to when it had 14.5k miles, see images.
- No shake/vibration under acceleration yet
Ford Maverick CV axle - Sign of leak and likely eventual failure 1777701320939-j2
Ford Maverick CV axle - Sign of leak and likely eventual failure 1777701425967-y3
Tbone289
MO
That small amount of weeping at the clamp shouldn't cause CV failure. There's still a lot of grease in there.
