Coolant for hybrid battery loop
Man_Solo
San Diego
Hey Maverick fans!
I’m trying to find the right coolant for my hybrid battery, and I was hoping you could lend me your expertise! I’ve attached a photo so you can see the engine coolant is yellow, and the hybrid battery coolant is green. My green coolant needs a refill, but the parts guy at my local dealership says I should use the yellow coolant instead.
Does anyone know if these two different colored coolants are the same or different? Thanks a bunch for any help you can offer!
P.S. I got the Motorcraft coolant shown here because I’m pretty sure it’s the right one for the engine.
Ford Maverick Coolant for hybrid battery loop Coolant
Ford Maverick Coolant for hybrid battery loop Screenshot 2025-10-29 at 3.48.35 PM
Same color actually - open caps to see.
Same coolant.
Otherwise known as Motocraft Yellow. That's the right stuff.
Which is not the same as the yellow that came before the green, that came after - never mind, starts getting stupid.
Capacities
Variant Quantity
Low temperature cooling circuit.​
4.8 qt (4.5 L)
High temperature cooling circuit.​
11.7 qt (11.1 L)
Materials
NameSpecification
Motorcraft® Yellow Prediluted Antifreeze/Coolant
VC-13DL-G
WSS-M97B57-A2
Carlitos_92
PSA: The battery coolant has a cleaner environment than the coolant that goes through the engine block. Only reason for the apparent color difference. :wink:
Waterick
Laurens county SC
Did you buy the Maverick new? Has any coolant been replaced, if not then maybe the coolant did change color with use, because they did start out the same.
Man_Solo
Man_Solo
San Diego
Same coolant.
Capacities
Variant Quantity
4.8 qt (4.5 L)
11.7 qt (11.1 L)
Materials
NameSpecification
VC-13DL-G
WSS-M97B57-A2
That makes total sense. I just wanted to be as close to 100% sure as possible. Thanks so much for your response.
Man_Solo
Man_Solo
San Diego
Ah yes, that is something I did not even consider in my thought process. Your answer makes complete sense to me. Thank you for providing your insight, I appreciate it very much.
Man_Solo
Man_Solo
San Diego
This car has been on the road for 19K miles! Before I got it, it wasn’t officially registered to anyone. A friendly dealership owner in SoCal drove it around before CARMAX sold it to me. Plus, it’s a “First Edition” trim level and even made an appearance at the 2022 LA Auto Show!
Waterick
Laurens county SC
Some early hybrids did have some issues requiring service or repair of the HVB heat exchanger/cooling system. Perhaps yours had the coolant replaced and maybe you need to be watchful for further problems if it's low now. I don't see a perceivable difference in the colors on my '24 with almost 11k miles.
Robot-Wrangler
Kentucky
My FORD dealer refilled both cooling systems on my hybrid with green coolant. It's not yellow.
Marty
2026 Ford Maverick Tremor
So, are you guys telling me that if the LiPo battery cooling system springs leak in a Mavbrid the LiPo drive battery overheats ?
How far away from your house do you guys have to park to kept your family safe?
You’ve got to be kidding right ?
It won't overheat at a certain temp the electron in electron out function is turned off. Many pop ups will show on dash. Family will evacuate due to my screaming forbidden words.
Marty
Dat's sum funnay chit rite there man !
