Coolant for hybrid battery loop
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
So, are you guys telling me that if the LiPo battery cooling system springs leak in a Mavbrid the LiPo drive battery overheats ?
How far away from your house do you guys have to park to kept your family safe?
You’ve got to be kidding right ?
Nah man, I drain the fluid all the time and let it heat up, it's perfect for cooking burgers while boondocking. :p
The entire liquid cooled thing is more recent in hybrids, my previous hybrid had an air cooling system. That was far less hassle, and didn't need a bunch of extra stuff on the vehicle. Why they went away from that, besides allowing for heating during winter, is beyond me.
Cherokee
Marty
2026 Ford Maverick Tremor
I hear ya. I’ve said it before, I think these new vehicles, all makes are needlessly over complicated.
Water cooled looked more efficient and likely showed it’s better for the battery during R&D.
Temp stability with water is likely greater.
But still,
mspmms
'MERICA 😎 A gulf is named after it ---> and now a lake too!
2022 XL Ford Maverick 🇺🇸
My FORD dealer refilled both cooling systems on my hybrid with green coolant. It's not yellow.
That could be a problem or undesired - as the 25MY is the same coolant spec'd.
Is it a problem? Depends if that was Ford green
https://www.fcsdchemicalsandlubricants.com/quickref/coolantsEN.pdf
Glancing at the chart you get a quick sense regarding the Ford green - if that's what it was.
25MY spec.
COOLING SYSTEM CAPACITY AND SPECIFICATION - 2.5L, HYBRID ELECTRIC VEHICLE (HEV)
Use coolant that meets the defined specification.
If you do not use coolant that meets the defined specification, it could result in:
  • Component damage that your vehicle warranty does not cover.
  • Reduced vehicle performance.
Capacities
Variant Quantity
Low temperature cooling circuit.​
5.0 qt (4.7 L)
High temperature cooling circuit.​
9.6 qt (9.1 L)
Materials
NameSpecification
Motorcraft® Yellow Prediluted Antifreeze/Coolant
VC-13DL-G
WSS-M97B57-A2
Note: Yellow coolant may become darker over time. This is normal.
