Converting Hybrid to a plug in hybrid...
Vmontello
Vin
Clayton, nc
2023 Maverick XLT LUX
Short version:
It's easier than you think.
It's 10x more expensive than you think.
It doesn't do what you think it would do.
What it did for the Escape was NOT add 40 miles of EV range.
What it did do is boost the 36 MPG to 60 MPG tor the first 40 miles.
Basically the car's behavior remained the same. But the second battery would constantly recharge the stock one, instead of the engine. So it was like going downhill for 40 miles.
Without rebuilding EVERYTHING, by using the same software, same wires, same motor, same transmission, with a second battery the amount of amps; the amount of boost, the amount of EV horsepower remains the same. If you have to granny it in a parking lot now to stay in EV you'll have to granny it with more battery.
Just the length of time you can granny it gets longer.
Thanks for the actual answer. No snarkiness, just facts. Much appreciated.
AutobahnSHO
Will
S.Carolina
Maverick, Miata
Short version:
That's pretty interesting- the easiest way to go.
The Volt or other PHEVs (which can drive faster speed pure electric) would be a lot more complicated, and I wonder what the cost would be...
LSchicago
Lloyd
IL
It may be possible earlier if Ford has enough lithium they can transfer to maverick from the EV production cutbacks.
It could come as early as 2025 MY, or late as 2028 MY.
The Real Maverick
Jack
You'll note you cannot start this hybrid in Neutral while you are standing still.
This is because if power is applied to the Motor/Generator that is also the starter, the wheels could turn, and the unexpected movement could cause damage or injure someone.
You CAN start the truck while rolling in Neutral over 6 mph because hey, you're already rolling so probably not a wall or person standing there.
See also: there is no "neutral".
(There's only freewheel.)
Vmontello
Vin
Clayton, nc
Not trying to be a dick, but wondering what does this neutral thing have to do with the question?
The Real Maverick
Jack
It means the starter motor can send torque to the wheels too; not just the traction motor, talked about by someone else above. That's all.
Two motors, two generators in these trucks.
Jared
Jared
Ford Maverick XLT
Is anyone else wondering why anyone would want to do this, given the circumstances of the OP?
I often wonder why people wear masks in cars when they’re alone too though so maybe I’m the idiot.
Automate
Atlanta GA, USA (ATL)
Fusion Hybrid, Mav XL Hybrid
Was there a DC-DC charger between the new extra batteries and the original batteries? Or were the extra batteries just connected in parallel with the original batteries?
MaveRichard
Rich
MI
2023 Ford Maverick XLT Hybrid
I don't believe that's correct, I believe both electric motors can provide power.
In both the Prius Prime and Prius Plug-In MG2 can add an extra ~20hp (depending on the year) because of an extra sprag clutch/brake on the input to the planet carrier of the power split device inside the eCVT.
Edit: Maverick hybrids do not have this sprag. Only the traction motor can provide forward torque while the engine is off. Any torque produced by MG2 in this state would be transferred to the engines crankshaft through the damper.
Mav_RICK
Rick
Arizona
Ford F150
It’s likely to be the only way anyone will ever have a PHEV Maverick. I just don’t see Ford finding a market for considerably higher priced and more complicated Mavericks with very low economic return on the investment.
The Real Maverick
Jack
In the very early days, no DC/DC.
The second battery was in parallel.
I was only involved in 2007-2008.
I don't know the "current" state of the art.
olderbudwiser
I've read this is possible with some hybrids but wondering if anyone has heard of it done with a maverick. Since I drive mostly locally I'd love to be able to get 20-30 miles without the ICE kicking in.
Anyone?
I suppose one could look into a totaled Ford Escape or Lincoln Corsair PHEV. Would all the work involved be worth it. That would be you you to decide.
Automate
And you would not get the PHEV tax credit that is offered on some PHEVs and can sometimes justify their extra cost.
surfstar
2023 XL Hybrid
Very key.
We owned a couple Prius Primes and a Rav4 Prime - never would have made fiscal sense to purchase without EV tax credit and other rebates.
I loved having the ability to run around town on battery only. However my $24k Mav hybrid can get 50 mpg around town. $4 of gas = 50 miles. A PHEV won't pencil out. If it qualifies for the full EV tax credit and comes with AWD without loosing too much mpg - maybe I'd bite. I prefer value-priced vehicles and no way that a PHEV Mav will be any other trim than fully loaded, unfortunately.
