Concern with Buying Used Maverick with Aftermarket front tow hooks?
AggieDrew
Drew
Manvel, TX
2023 Ford Maverick Lariat
I just purchased a used 2023 Lariat that is in good shape and I really like it. However, I realized after reviewing the threads on here that the front tow hooks and 6 pin connector were not part of the Ford tow package (this is not the 4x4 Maverick) and were an aftermarket job. I'm still in the 5 day grace period on the purchase from the dealer (it wasn't a Ford dealership). It does not seem like this modification would void any warranties, but should I be concerned about this modification or go get it checked out by a Ford shop? It's not the cleanest cut job on the front panels but I'm less concerned about the aesthetic impact. It looks like it was possibly used to pull behind an RV.
Ford Maverick Concern with Buying Used Maverick with Aftermarket front tow hooks? picture1
Ford Maverick Concern with Buying Used Maverick with Aftermarket front tow hooks? picture2
Ford Maverick Concern with Buying Used Maverick with Aftermarket front tow hooks? picture3
TheShark
Yep, I'd say it was towed.
fossil
ernie
ohio
setup for towing behind a motorhome (y)
Billy2mav
William
Abington
I hope the rest of the truck is in really good shape and you get a good deal. That doe's not look good.
Johnkn
MD
It appears who ever cut the front bumper to install the mounting points used an axe (and missed a few times). With that terrible workmanship I would question the entire install. Do you even need a flat-towable Maverick?
I could never un-see that and personally would walk away as I have zero need to tow my Maverick and could not live with that front end now, but you do you.
S Dundee
Guest
Agree with @Johnkn. I also could never un-see that. Really bad workmanship and probably not good for the hybrid to be towed behind a trailer either. They probably also cut into the wiring harness (2nd photo) which has caused many hybrid owners much headache. You don't need the hassle. Unless they knocked off a heckuva lot of cash, if it were me I would take it back.
The modification likely does void parts of the warranty. There are numerous posts of electrical mods made by 3rd party installers cutting or splicing into factory wiring and causing many problems. That is not covered by Ford. Likewise, if those tow hooks which were badly installed (and appear crooked) deformed the unibody structure, that is not covered by Ford warranty. You likely have no recourse with the company who did the bad install of the tow behind parts as you are the 2nd owner and not the one who purchased it.
Mc_Flier
Area 51 Maverick Hybrid, Street Glide Special
What a hack job.
Vols44
Missouri
2018 Edge
The YT video in a related thread explains the frame and support plates on a FX4 version versus a hybrid and their limitations. I'm looking at the installation of front hooks on my hybrid for emergency/limited use and I'm not ready to cut up the front fascia until I'm sure where the anchor points will be and the effectivness of the install.
Redline
Upstate, NY
Personally, I'd pass on that one. The installer's skills are in question and who knows how many miles it's been dragged around the country. I don't think that tow miles show up on the odometer.
Maybe you could work getting it back to stock appearance into the deal, if you must have it.
AggieDrew
Drew
Manvel, TX
Thanks for all the info! The wiring is coming in above the shutter but hard to track back after that. Wasn’t planning on using it to tow myself but all the wiring/warranty risk is definitely worrying.
