Charging via solar (to keep battery charged when sitting for long time)
Ippolito
Robert
Madison, CT
'25 Mav, '20 Meredes Benz GLA, '21 Mercedes Benz C300, '05 Chevrolet Corvette
My Maverick sits for long periods, only did 4k in 2025. Does anyone use solar to keep their battery charged?
Mavster Mechanic
Hybrid
You can, but you need to buy a specifically made for battery charging solar panel that has a charge controller built in or add a charge controller.
Example: a plain solar panel can consume power at night, so you'll need one that automatically disconnects in the dark.
Also voltage can vary a lot with sunlight changes so you'd want one with good voltage control, and one that shuts off in daylight when the battery is 100%.
Mavster Mech,
Can you find us an example that meets your stated criteria ?
And tell us how to hook it up ?
I’d love to buy one that operates and can be controlled like you stated.
I’ve had no luck so far.
Quest
Built several for stock vehicles when I worked for a dealer
Cost about $30 each
15W & Plugs into the OBD2 connector
Quest
Just a diode to prevent reverse current at night.
You need to remember its not always sunny, at least not where I am so overcharging will never happen.
It will extend the time the battery goes dead from a month to 6 or 7 months
Your Maverick has a constant draw when sleeping of about 15ma & 22ma for a hybrid
The TCU periodically sending data to Ford will also draw a few amps for short periods
Had 1 Ecosport on the lot for 8 months with the solar charger & it started up no problem although the brakes were so rusty the rotors had to be replaced
Mavster Mechanic
Hybrid
I am not recommending any one in particular.
But Amazon should have dozens to choose from.
inline_five
2023 Hybrid XLT
I have this exact same unit and it's been in use for several years. It does charge but if put inside the vehicle with a sunshade, it will get EXTREMELY hot and the glue melts. Fortunately, I don't care about the sunshade but it's something to be aware of.
I park on the street but if it was in my driveway or away from others I would put it outside on the windshield. I try to park facing south to give it the best light.
It's extremely effective at keeping the battery charged up.
Carlitos_92
Tim d
Alpena
Ram
Following...Great idea...if....you can find a panel big enough to sufficiently charge.
2lbgill
Don
Upper Peninsula MI.
2023 XLTHybrid
What they consume is off the grid and neglectable
MaverickDragon
Grand Canyon, AZ
Considering the parasitic draw is milliamps, you don't need a large solar panel to keep your battery charged. A large panel will need a charge controller, as the risk isn't to sufficiently charging the battery, it's the risk of overcharging it which will cause damage.
JonP_Maine
Jon
Veazie Maine
2025 Ford Maverick XL
icegradner
British Columbia, Canada
2022 XLT Maverick Hybrid
Yeah I need it. I use a battery maintainer, a bit of a pain with my truck parked outside, but it's back into deep sleep after 3-4 days even with regular driving to work.
