CarPlay acting up?
Darthie
Frank
All of a sudden my truck defaults to am or fm rather that Airplay. I use a wireless dongle. It’s worked fine for months and know I have to manually select airplay every time I start the car. Any ideas as to what caused this change?
Do you have the truck options for WiFi enabled and auto-updates?
Perhaps there was finally one - and this is side-effect.
The non-Sync3 update I got for the rear-view camera recall, is constantly putting my screen back to Home, rather than the FM screen I had it on at turn-off.
Might also confirm if anything on phone related was upgraded.
Darthie
Darthie
Frank
I have not connected to wifi that I know of.
canuckford
Lou
toronto ontario canada
2025 2.0L ECO, 2015 Transit T250
What dongle do you mean? Pretty sure the airplay and android auto use Bluetooth instead of WiFi for the dash screen communications. Is your phones Bluetooth on?
Every phone built in the last 100 years has Bluetooth so not sure why you have to use a dongle.
Carlitos_92
OP is using a dongle to make his CarPlay wireless. Otherwise in the stock 2023s CarPlay is via USB cable only.
And CarPlay doesn't run over BT; you can watch the head unit display disconnect the phone when CarPlay fires up.
lewiskauffman
Lewis
Chambersburg PA
2022 Ford Maverick XL
Apple just released iOS 18.4.1 which is supposed to fix a bug with Carplay on some vehicles. Might check it for your problem.
Dmthomp32
Doug
Charlotte
2023 Ford Maverick
Doesn’t matter. I’ve tried two different dongles, Bluetooth and direct wired CarPlay. They all have issues eventually and drop off sporadically.
Bluetooth connects to Wi-Fi for data stream. Bluetooth handles smr texts and short packets. Dropping out occurs when cell towers lose connection.
canuckford
Lou
Sorry, didn't know the 2023's had to connect via USB cable only.
I have a 2025 Eco-B, and it definitely uses Bluetooth, I'm using android auto.
For the OP, I'd definitely keep shopping around for an adaptor that is more compatible with his phone.
canuckford
Lou
Reply to my owm message, I think android auto using both, WiFi and Bluetooth. Will do some reading up.
canuckford
Lou
Here's the lowdown. So perhaps the ops cellular service is flakey.
Yes, Android Auto does require Bluetooth to establish a wireless connection, although it can also utilize WiFi for the data transfer once the initial pairing is complete. Initially, Bluetooth is used to pair your phone with the car, then WiFi takes over for data transmission.
Elaboration:
  • Bluetooth for Pairing:
    The first time you connect Android Auto wirelessly, you'll need to pair your phone and car via Bluetooth.
  • WiFi for Data:
    Once the initial pairing is done through Bluetooth, Android Auto can then use WiFi to transmit data between your phone and the car's infotainment system.
  • Optional WiFi Hotspot:
    Some cars have built-in WiFi hotspots, which can also be used to connect Android Auto wirelessly.
  • Data Plan:
    While Android Auto primarily uses WiFi for data transmission, you may still need an active data plan on your phone for certain features like online navigation or Google Assistant to function correctly.
Ford Maverick CarPlay acting up? 1745155257311-tz
Ford Maverick CarPlay acting up? 1745155257416-
