Trying to get info if you can unlock navigation through forscan if you have a lariat maverick. If so how? Thanks
Agreed. What is the reason for wanting built in Nav?No, I do not think you can. it is a different APIM module installed for with nav to without nav.
I suggest buying a cheap $30 cell phone to keep plugged into the truck for Android auto maps. and just use mobile hotspot on you main phone for the internet for it.
I am guessing the OP was just curious. If it could be turned on for free with Forscan, why not go ahead? ...But, no. It's a different APIM board with GPS and it's around $500, give or take. You could get a new or used Garmin for less. (They go for $170-350 depending on screen size.)As stated it does require a different apim since the non nav only have 16gb of storage and the nave ones have 64GB to hold the map data. If you can find a apim it’s an easy swap and it should work without changes of it comes from a maverick
if you have sync3 already - lariat lux - it's easy to swap and your Ford dealer can authorize the new APIM which will mean you can download updates over the air and it'll behave the same as if it left the factory with GPS.Last one I seen on the net was $1100. for the Apim and gave instruction on how to change it. It also advised not to take any Ford updates.
that could've been your own thread, as it's not really relevant to the OP's question or issue... but since you replied here, I will answer also.I just finished installing a new Kenwood head unit in our motorhome that supported both wireless Apple Carplay and wireless Android Auto. Wanted it to match our other vehicles. Makes it so easy to switch cars. Just get in and your paired up and ready to go.
